Cam Only Dyno Thread
Old Jul 3, 2011 | 07:14 PM
  #461
KFC_Or_Bust's Avatar
1999 Trans Am M6
Comp Cams Custom Grind .610/.613 242/246 110 LSA
7.4" Pushrods
Patriot Gold Valve Springs
QTP Long Tube Headers & Catless Y-Pipe
SLP Loud Mouth II Catback
Lid
4.10s
Stock 843 heads
Stock LS1 Intake
Stock MAF/TB (descreened MAF)
Ambient temp of 85~ degrees.
Don't ask me how but it laid down 445.2 whp on a Dynamics Dyno...Do they read higher than other dynos or something? lol
http://www.youtube.com/watch?v=x_HGIHlKBpg
Old Jul 9, 2011 | 07:33 PM
  #462
s10-den's Avatar
Holy chit!! If thats right, thats some serious numbers!!
Old Jul 20, 2011 | 08:16 PM
  #463
quicksilverZ's Avatar
02 Z06 Vararam, Fast 92/90, G5x3, Catless LGpro LT's, UDP, tune. 440 rwhp / 400 rwtq
Old Aug 23, 2011 | 12:05 AM
  #464
juniorz28's Avatar
422 horsepower 379 torque mods are in my sig..
Old Aug 23, 2011 | 08:16 AM
  #465
Black 99 Bird's Avatar
Originally Posted by KFC_Or_Bust
1999 Trans Am M6
7.4" Pushrods
Lid
4.10s
Stock 843 heads
Stock LS1 Intake
Those are probably uncorrected numbers, just guessing?
Old Aug 23, 2011 | 10:18 AM
  #466
CaMaRo67RS355's Avatar
My 02 SS cam only put 46x/42x with MS4 through a 6 speed and 9" with 4.11 gear and bolt ons (full exhaust, ewp, speed density, intake and tb) on a dyno jet. Stock heads never unbolted just higher lift valvesprings, stock bottom end. The tuner thought it was a fluke so we dyno'd it several times after that and it was almost identical everytime. I put several hundred miles on it every month at least I dont believe in being limited to where or how often you can drive it. Drivability wasnt bad at all I had 0 issues.
Old Aug 24, 2011 | 08:09 AM
  #467
What tb and intake are you running?
Old Aug 25, 2011 | 06:47 AM
  #468
NW 92mm TB and 92mm Fast Intake Ported
Old Sep 10, 2011 | 08:49 PM
  #469
mshadow's Avatar
1998 LS1
TReX
Katech rodbolts
Pacesetter headers
LS6 intake
Ported TB
Dual valve springs
3 inch X pipe 4x9 magnaflows
10bolt 3.73s
420/380
Peaked at 6300 and carried it out.
Old Sep 12, 2011 | 06:49 PM
  #470
studderin's Avatar
Originally Posted by studderin
streetsweeper cam from New Era, ed C
236/240 .630/.612 111+3 t56 steel flywheels and DS, 28" Drs, 2OTL, paper filter, belt on. Dana 60 w 4:30 gears
425/393
New custom grind form newera. Test a few cams, sent the data to EdCutis, asking if He could make more power for my setup for stock heads, and still street drive the car. Made a few pulls this weekend.
441whp/395 gona work on it should make a few more hp. NO surging at all, drives great. Will post the graph in a few days
Old Sep 12, 2011 | 06:57 PM
  #471
studderin's Avatar
Also my car made 433 with a Trex cam. acuttly made a little more tq 400wtq but at RPM I never see. It also drive alot worse and surged low rpms.
Old Sep 16, 2011 | 09:29 AM
  #472
GoFastKid's Avatar
1999 Trans Am M6
7.4" Pushrods
Lid
4.10s
Stock 843 heads
Stock LS1 Intake
With a cam that size I bet the car drives like **** from all the surge and I would imagine it lags until your reach the higher rpm range. A smaller 224 - 226 cam would spank it.
Old Sep 17, 2011 | 01:03 AM
  #473
Yeah it's pretty surgetastic, still don't have a real tune on it though. It is a tiny bit on the "laggy" side down low but more than makes up for it mid-top end. It built power up to 6800 rpm then tailed off 2whp to 7000...That was as far as I was taking the stock bottom end on the dyno, limiter is set for 6500.
Old Sep 17, 2011 | 09:42 AM
  #474
studderin's Avatar
forgot to post this
Old Sep 17, 2011 | 12:01 PM
  #475
GoFastKid's Avatar
So why such a large cam? A much smaller cam would have netted a lot more usuable power rather then this one..just curious..
Old Sep 17, 2011 | 01:32 PM
  #476
Bought it that way, I don't really mind it though.
Old Sep 20, 2011 | 06:41 PM
  #477
99articfrc's Avatar
05 c6 hps custom antivnm cam only, headers, cai, borla 447 hp 400 tq what what hps all the way!!!
Old Sep 27, 2011 | 04:33 AM
  #478
SlickShoesC6's Avatar
05 C6 6 speed here too, custom 234/240, .598/.608, 112+3 w/ supporting valve train, Vararam, Ported Fast 92, ARH 1 7/8" LT's & 3" catless mid, SLP LM1's. Aft of the engine is a Spec aluminum fly & stage 3+, C6 Z06 trans/diff/axles, and cast Z06 19x12 repros (heavy).
Car made 460/426 to the tires just last week (rounding to the nearest whole number).
Old Sep 29, 2011 | 10:25 PM
  #479
NoShow's Avatar
Wow, you are probably the most mild-mannered guy on any forum I've read
Old Oct 10, 2011 | 10:57 PM
  #480
LS1Adam84's Avatar
2000 Z28
TSP 228R
228/228 .588 .588 112 LSA
241's milled .042"
TSP ported and shimmed LS6 oil pump
In motion timing chain set (ordered LS2 but TSP was out and they said this was just as good)
PS headers
TSP ORY
Magnaflow catback
FTI 3800 stall
stage 2 xtreme performance trans
3:42 gears
LS6 intake
SLP lid
put down 366/366 and this is with a nice howl coming from the axle housing, pretty sure I need to rebuild the rear here soon.
Runs 7.4/7.5 at 92 mph at the local 1/8th mile track
Planning on going to an MS3 and 243 heads, atually I am doing some research to see what I can get the most power for my car with, I might get an engine profile program here and fool around with it.
