View Poll Results: HoW much RWHP are you making?
300-330
16.83%
330-350
11.58%
350-400
18.75%
400-450
21.64%
450-500
9.51%
500+!!!!!! Yeahhhhhh
21.69%
Voters: 3766. You may not vote on this poll
How Much Power Are You Making @ The Wheels?!!?
Old Mar 3, 2008 | 01:31 PM
  #581
joshua022's Avatar
390rwhp and 366rwtq on a H/C 5.3 on 93 oct
scan0004.jpg?t=1204403905
Old Mar 6, 2008 | 12:37 AM
  #582
Dookie454's Avatar
LT1
570rwhp @ 7psi
http://www.youtube.com/watch?v=JTIh0fpvspw
Old Mar 10, 2008 | 08:01 PM
  #583
bluebeast's Avatar
1994 LT1 355 vortech S trim on 9.5psi T400 12 bolt 545rwhp.... i sold my S trim and almost saved up for the YSI and plan to run more boost so maybe 700-800rwhp in the future??? stay tuned
2002 LS1 M6 longtubes, y pipe, flowmaster muffler with factory exaust pipes 348rwhp
on a side note i just installed a magnaflow catback and it has never been tuned so it should be a lil more just with a real 3 inch catback and then more for a tune but im waiting till the powerbond pully
i just installed a fresh 388 stroker with dart heads and decent cam and all the bolt ons.... its a street motor and i didnt want radical hp cause iw ant it be reliable but it shold still have around 400rwhp..... throw in a solid roller cam, hog them heads out more and we have probly 100 more hp....it can handle a big shot of gas so the skys the limit there but i havent even started it yet so im just chattingon that car... i should have some numbers in a few weeks
Old Mar 13, 2008 | 11:31 AM
  #584
2000KnightRider's Avatar
402 to the wheels
Mods in sig
Old Mar 14, 2008 | 09:49 PM
  #585
canada4g63's Avatar
870whp
mods are
ENGINE
RevXtreme 408 cid Iron Block
Harland Sharp 1.7 Adjustable Roller Rockers
RevXtreme/Felber Race Heads
Comp Cams Chromoly Pushrods
Comp Cams Lifters
Roll Master Dual Roller Timing Chain
Cometic Performance Gaskets
Keyed Balancer
Callies Rotating Assembly
Diamond Forged Pistons & Accessories
RevXtreme �Big Dog� Cam
Fast Intake 90mm Manifold
Fast 90mm Throttle Body
Meziere Electric Water Pump
SLP under drive pulley
MSD Super Conductor Wires
Nitro Dave�s Stand Alone Aluminum Fuel Cell
NITROUS SYSTEM
NX EFI8000 200-500HP Direct Port Nitrous Kit with 15lb Bottle �6 line
NOS 5177 Dry Nitrous Kit
Custom Nitrogen Push System
Aeromotive Fuel Rails
EXHAUST
3.5 inch all mandrel bend custom with dual 5-inch Dynomax bullets
QTP 1 7/8� Long Tube Headers
SUSPENSION & CHASSIS
BMR Adjustable Torque Arm
BMR Full Length Relocation Cross Member
BMR Upper and Lower Tubular A Arms
BMR K Member
BMR Moly Adjustable Race Control Arms w/relocation brackets
BMR Moly Adjustable Race Pan Hard Rod
BMR Xtreme Duty Rear Drag Race Swaybar
TRANSMISSION & DRIVETRAIN
Spec Stage 5 Billet Steel Flywheel
Spec Stage 5 Pressure Plate
Spec Stage 5 Disc
ACPT Carbon Fiber Drive Shaft
Ford 9 inch Custom F-body rear w/ spool and 35 spline axles
Old Mar 14, 2008 | 10:05 PM
  #586
99DWPTA's Avatar
1568 WHP
Semi turbo
1.8L VTEC
J/k 406whp
Old Mar 15, 2008 | 10:09 PM
  #587
canada4g63's Avatar
Originally Posted by 99DWPTA
1568 WHP
Semi turbo
1.8L VTEC
J/k 406whp
If you have vtec you win hands down
Old Mar 15, 2008 | 10:33 PM
  #588
James Montigny's Avatar
1568 WHP
Semi turbo
1.8L VTEC
I think you forgot your decimal point
Old Mar 17, 2008 | 09:33 PM
  #589
vaticano's Avatar
Here's my new dyno sheet
723 rwhp 654 rwtq corrected 1.20
actual 603 rwhp 545 rwtq
Attached Thumbnails How Much Power Are You Making @ The Wheels?!!?-img_0002.jpg
Old Mar 19, 2008 | 05:04 PM
  #590
jcoker's Avatar
550 with a L92 427 and tfs heads through a m6 camaro
Old Mar 22, 2008 | 09:48 AM
  #591
camaro98z28's Avatar
Holy Mountain Batman.
Old Mar 22, 2008 | 10:18 PM
  #592
Detoxx03's Avatar
414 rwhp and 386rwtq through boltons, 3600 stall, futral motorsports cam ( 228/230), fast 92mm intake, ptm 92mm tb
Old Mar 23, 2008 | 12:28 PM
  #593
35th annivSS's Avatar
305 rwhp corrected. The car is bone stock. 225 rwhp at altitude. Damn the altitude in CO.
Old Mar 28, 2008 | 09:25 PM
  #594
Hippi's Avatar
here ya go bone stock 02 SS with the 345hp center out option
Old Apr 6, 2008 | 07:58 PM
  #595
TXZ28LS1's Avatar
im making 395rwhp stock heads on my auto!! MTI X1, stock heads, vig 3200 stall all bolt ons except pulley and still rolling crappy 2.73!
Old Apr 6, 2008 | 09:03 PM
  #596
_.:LS1GTO:._'s Avatar
456rwhp/403rwtq
Mods in sig
Old Apr 7, 2008 | 03:52 PM
  #597
3rdgentug's Avatar
numbers in sig are always up to date!
need a better tq converter, i just dont think this fuddles gonna cut it.
car has more in it , tuner n i are gettin back on the dyno and do some street dataloggin done here real soon.
probly get a few more ponies to the rear as well as more tq!
( im hoping for the low 420'srwhp and mid 380's tq )
p.s. and soon to come is a forgered ls3 aluminum block and probly a lil gas )
Old Apr 10, 2008 | 05:57 PM
  #598
STRETCH'S T/A's Avatar
420 rwhp, 387 rwtq from full bolt ons, SS3600 stall, 90/90 set up, and a G5X3 cam from LG Motorsports.
Old Apr 16, 2008 | 12:17 PM
  #599
96WS6guy's Avatar
342 rwhp 364 rwtq. Mods in sig. Apparently that isn't so bad for what I've done to it so far.
Old Apr 20, 2008 | 12:55 PM
  #600
Avengeance's Avatar
568rwhp/551rwtq
