D-1SC dyno #'s?
Old Jul 17, 2005 | 04:32 PM
Steve C.'s Avatar
Default D-1SC dyno #'s?
I was just checking on dyno numbers at around 9 psi with an ati D-1SC with my current mods. Im trying to decided if i should buy the d-1sc or just get the S2 heads and cam from MTI, possibly with FAST 90/90. Im guessing the S/C setup would make more power and have better drivability. Any advice, dyno numbers, setups, etc. would be greatly appreciated. thanks.
Also any reccomendations on a new clutch for either of those setups
Old Jul 17, 2005 | 08:38 PM
WHPLASH's Avatar
You'd probably push 425-450 to the wheels with only 8lbs.
Old Jul 17, 2005 | 10:52 PM
maxf's Avatar
My P-1SC hit 458 rwhp and 415 ft/lbs tq. at 8 psi. Car is completely stock minus the blower and a 255 LPH Walbro.
Old Jul 17, 2005 | 11:31 PM
Black02hawk's Avatar
and the d1 is bigger than the p1 right?
i was at a car show this month and saw a monte with a d2...the thing was huuuge
Old Jul 18, 2005 | 09:34 AM
LSs1Power's Avatar
548rwhp 500rwtq with 8psi
Old Jul 18, 2005 | 07:51 PM
black01_WS6's Avatar
I was thinking about the same thing, but im thinking of getting rid of the LT and getting a turbo.
Old Jul 19, 2005 | 11:44 AM
LETZ RUN's Avatar
my car dyno'd 505rwhp 460rwtq completely stock w/ longtubes, ypipe, slp loud mouth. d1sc @ 9lbs.
Old Jul 21, 2005 | 03:47 PM
John02SS's Avatar
The D1SC car will make more power at peak, but the H/C cam if done right will be faster. I ran a Formy with a D1 on it making 462 rwhp in a 6 speed with my 457 rwhp H/C setup and I got him pretty good several times. Now a H/C, 90mm, D1 car would rock!
Old Aug 3, 2005 | 06:36 PM
HartAttack's Avatar
John proved my theory right...that a H/C cam making "about" the same power as a stock car with a Procharger at 8# would win due to a more broader powerband.
but to update my numbers...i did 442/424 with my cutout open in 92 degree heat and 52% humidity...versus the original dyno in california at high fifties to low sixty degree weather.
When i ran John i was threw the hooker catback...431/420
I do like the procharger setup alot though....car drives stock like untill you go WOT. Headers and cam...easy 500hp mark
Old Aug 3, 2005 | 08:57 PM
LSs1Power's Avatar
Show me a H/C car that makes 400rwtq at 3K RPM and 500rwtq at 4200RPM. You would have to compare a D-1SC car with stock bottom end to at least 408+ LS1 with a big cam and every last bolt on possible.
Old Aug 4, 2005 | 12:28 PM
30th t/a's Avatar
gears will make up for the lack of torque.
