H/C with JBA's
Old Jul 22, 2006 | 07:39 PM
52172's Avatar
Default H/C with JBA's
Here is my graph from Superior Auto in Anaheim Ca. Car is an m-6 with all bolt ons and a 222/224 114 cam through offroad y pipe and out magnaflow catcack cut out closed.
Attached Thumbnails H/C with JBA's-img_0740.jpg
Old Jul 23, 2006 | 08:58 AM
98A4LS1's Avatar
Nice numbers! Ported stock heads?
Old Jul 23, 2006 | 09:28 AM
52172's Avatar
Yes ported stock heads with 2.02 1.6 valves flow 299@ .600 and 306 @ .650. Comp pro mag rockers 1.75 with a .581 lift comp cam. Power falls off abruptly at 5800 rpms not too sure why maybe the short tube headers or the way the cam is installed with a lot of advance. Anyway it drives great and has great torque and pulls very hard all the way to redline which is set at 6200.
Old Jul 23, 2006 | 09:30 AM
52172's Avatar
Oh numbers before were with same exhaust and an lingenfelter aluminum intake and slp 1:85 rockers with factory cam. Picked up 75 rwhp with the H/C package not too shabby huh?
Old Jul 23, 2006 | 10:06 AM
SouthFL.02.SS's Avatar
!LS1 11 Second Club
That's one very impressive, very streetable setup. Very nice.
Old Jul 23, 2006 | 12:33 PM
52172's Avatar
thanks bro!!!!!! It will even pass the Ca sniffer!! I have mufflex test pipes on there now I would just have to bolt in the factory cats in their factory location.
Old Jul 23, 2006 | 12:55 PM
jrp's Avatar
jrp
SN95 Director
whats SAE?
Old Jul 23, 2006 | 12:56 PM
52172's Avatar
Those numbers are std i believe so that makes them slightly higher than sae right.
Old Jul 23, 2006 | 03:24 PM
lilbuddy1587's Avatar
power falls off @ 5800 because of valve train instability
Old Jul 23, 2006 | 03:39 PM
52172's Avatar
wrong running new 921 comp valve springs.
Old Jul 23, 2006 | 04:24 PM
!LS1 11 Second Club
He may be referring to this: Comp pro mag rockers 1.75
Either way, it would be good to investigate why power falls off abruptly. The graph seems like that's simply where the pull was aborted.
Old Jul 23, 2006 | 04:28 PM
52172's Avatar
Does everyone have problems with the 1.75 rockers? I brought the car back and had them do a full pull to 6200 and it falls off pretty abruptly not sure why. the shop thought it was the small cam, but it might be the rockers? It was down about 15 horse power by 6200 rpms's. I do not have the funds to take it too a shop to put the stock rockers back on? Anyone else have problems with the comp 1.75 rockers?
Old Jul 23, 2006 | 04:33 PM
!LS1 11 Second Club
Putting stock rockers back on is very easy. Give it a try, pull a few more times on the dyno and see the results. Wouldn't hurt.
Consult www.ls1howto.com for install info. Rocker removal and install is detailed in the cam swap section if I recall.
Old Jul 23, 2006 | 07:03 PM
There's more to it than just your springs So before bluntly saying I'm wrong, you should investigate it a little further as southflo. stated.
Yes, people have lots of problems with the aftermarket rockers being too heavy and it usually shows at about 5800-6k rpms. So, I'd do as southflo. said and change back to the stockers. It's pretty easy
