Cam only Ls1 440rwhp (Vengeance + Harris Tune)
#81
Originally Posted by 30th t/a
3550lbs, 410rwhp & 124 traps??? you better have some damn good weather and driving.
A few years agowe had 3700 lb 385 hp cam only M6 trap 120. Ive got 25 on Brents setup and a hundred fifty lbs, with sloppy driving it went an easy 122
#82
Originally Posted by wazslow
Should be a good time on saturday. I am the other car he is running. 03 Cobra (CAI, Magnaflow catback, 2.76 pulley, predator with mile hi dyno tune.... We had a little chance to run on saturday when he picked up the car and it seems that it will be a VERY close race. Cars with my mods have trapped in the 120-123 mph range i believe.
Your gonna need more than that to beat his car.
Most cobras w/ your mods trap 118-120, 120 if you can drive. powershift that bitch, keep it in boost. Fairless' car will trap 124 no prob.
you need a ported blower and long tubes if ya wann a trap 122-125.
Good luck, should be a close run
![Chug! Chug! Chug!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_chug.gif)
#83
Originally Posted by GrannySShifting
85 degrees and it was the first time Ive driven a stick car down the track in 3 years. Maybe the car is a little lighter aroud 3450, but still 400 rwhp shoudl traps 120
400rwhp & 120 traps sound right.....400rwhp & 124 traps...does not unless your driving a very light car in great weather.
#84
122 came easy driving it worse than my grandmother at 85+ degrees, 124 in good air is what I would expect from 410 or so - 440 in decent air I expect 126 at 3500 lbs for sure
#87
I guess the pressure is defintly on to perform...
I don't think I will be powershifting, ever since I went the chrome-moly flywheel and spec 4 route, I have not been able to powershift what so ever. Sucks.
I'll give it a few trys though.
#88
What type of hydrualics do you have?
And the pressure to perform isnt up to you. It's the car. You dont have to have a good driver or even good tires to make good trap speeds. Trap is what tells the power number, ET shows how well the car is set up to go 1/4 mile from a stop.
#94
Originally Posted by Genesis_26317
Chrome-moly flywheel?
WTF did they start making those? Did I freakin' miss something. I hate when I never hear of something.
#95
Originally Posted by Boodyrider
BTW... Stock valves? I know that cam isn't running on stock springs, how about lifters?
#96
SPM heads? Help me out here...never heard of those. How do these compare with stock?
I was under the impression that these numbers were with "stock" heads...either LS1 or LS6 maybe.
#98
Well, after a quick search, I found two different descriptions of them...so I'll let him clarify. Either description did say they were worth a "marginal" gain over the typical LS1 head.
Interesting...never heard of this before.
#100
Originally Posted by Ron@Vengeance
LMFAO... We have made 440rwhp 4 times at our shop cam only.... Now this guy hundreds of miles away does it and its not real ![Icon Rolleyes](https://ls1tech.com/forums/images/smilies2/icon_rolleyes.gif)
I guess SmokinStorm that made the fake 450rwhp unlocked and is now running 10.70s@126mph with the same camshaft in an A4 is lying also... Along with Brad02Z06 who made over 500rwhp with heads/FAST/Our Vindicator camshaft/ Or how bout Dre01Z06 that made 440rwhp with an LS6 intake/stock heads.... The list goes on and on... but so do the haters
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
