Patrick G. cam results
Old Dec 11, 2007 | 10:16 PM
rocksws6's Avatar
Default Patrick G. cam results
Well I had Patrick G. spec me a custom cam a while back and he recommended a 230/232 110+2. But it came as ground as a 231.41/233.37 111+2. Not enough of a difference to complain about. Anyways my modifications are as follows: the cam, Pace Setter LT's, ORY, Magnaflow cat-back, ported TB, SLP lid, and a K&N air filter. Vengeance informed me of this and I wasn't aware of it but a K&N air filter loses 5-7 whp to a paper filter. Yeah I couldn't believe it. I have never heard that before but the K&N is coming out. I didn't buy a UD pulley because it would have put me out of my already blown budget. But anyways here's what I got, everybody feel free to give me your thoughts and tell me what you think.
Edit: M6, Stock heads, 2001 WS-6
File Type: pdf
Old Dec 11, 2007 | 10:20 PM
RedRocketZ28's Avatar
Nice numbers. M6 or A4? Stock heads I assume? Also,what year is your car?
Old Dec 11, 2007 | 10:25 PM
rocksws6's Avatar
Yeah I added it into my original post but its a 2001 WS-6 M6 on stock heads, cam only.
Old Dec 11, 2007 | 10:32 PM
EarlSS's Avatar
Very nice numbers!!! I was unaware of losing power with the K&N. I might get rid of mine now. Hows the street manners with this cam?
BayAreaSS's Avatar
Once again good numbers rock! My cam might be here tomorrow.
We'll see what my car does sooner or later
Old Dec 11, 2007 | 10:45 PM
rocksws6's Avatar
The street manners are just fine. The only time it surges or bucks is when I'm coasting it will surge if your below 17-1800. But if you going uphill or there's load on the motor there's no problem.
Old Dec 12, 2007 | 12:14 AM
Frost's Avatar
There is tuning left to be done if it is still surging at 17-1800. With that much overlap, sometimes it's a balancing act trying to get the aiflow down but having enough base airflow to keep it returning to idle and idling properly. It takes some time to get it right. It would be nice to have 2-3 cold starts for testing as well.
Old Dec 12, 2007 | 12:42 AM
12secSS's Avatar
Nice results, it doesn't surprise me to see you guys get around 390-400 with that cam. It is a very good profile! As for the surge, just like Steve said, a couple of cold start and it little more time invested and you shouldn't have any surging.
Old Dec 12, 2007 | 08:23 AM
quiet_storm98's Avatar
its good to see that you made good power with the cam..i picked up an identical pat g cam from another member on here so im happy to see that you put down solid numbers
Old Dec 12, 2007 | 03:44 PM
Patrick G's Avatar
LS1 Tech Administrator
Cams in that duration and LSA range work sooooo well with stock heads. Just look at the curves down low and up high. It's really good everywhere. A cam that would make more peak power would typically lose more down low than it would gain up high. Same for a cam in search of more low-end. This is a very balanced cam. Thanks for sharing the results. I love seeing a stock-headed car pull so nicely after peak power.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
Old Dec 12, 2007 | 04:08 PM
BriancWS6's Avatar
on gauze filters losing power to a paper one. They might not gain a lot, but they're not gonna lose a damn thing.
Congrats on your newfound power
Old Dec 12, 2007 | 04:32 PM
magius231's Avatar
well, I've always thought the same thing but without some really hard data I'm sure not going to dispute someone that does this stuff for a living.
Old Dec 12, 2007 | 04:41 PM
Redlinez's Avatar
I wish I had 01 spec heads and the intake. Nice numbers.
Old Dec 12, 2007 | 05:28 PM
BayAreaSS's Avatar
Yea it seems to be a good cam. I hope i have similar results!
Old Dec 12, 2007 | 09:17 PM
SouthFL.02.SS's Avatar
!LS1 11 Second Club
Nice torque curve.
What lobe profile is this cam?
Old Dec 12, 2007 | 10:32 PM
Redlinez's Avatar
Probably XFi/XER
Old Dec 12, 2007 | 10:44 PM
rocksws6's Avatar
Yeah I think it worked out really well. I think after I get some Tru-duals and a UD pulley it should really put down some nice #'s for a cam only car. Thanks again for your services.
They said that the paper filter had more surface area then the K&N. They said that they tested a couple years back and they have the equipment to test it so I'm not going to argue with them. I don't see what reason they would have to make that up.
Old Dec 12, 2007 | 10:46 PM
rocksws6's Avatar
Originally Posted by SouthFL.02.SS
Nice torque curve.
XFI intake/ XE-R exhaust
Old Dec 13, 2007 | 07:13 AM
BlackScreaminMachine's Avatar
Internet Mechanic
You did very well!
Old Dec 13, 2007 | 07:21 AM
ScreaminRedZ's Avatar
registered user
Good numbers!
As for the K&N filter thing. I had a paper filter in my 1999 Grand Prix GT. I dynoed it and then swapped out for a used K&N drop in and it gained 2 hp across the powerband. I'll try it again with my Z28 next time I dyno it though.
