Let's discuss dyno calibration and consistancy
A 347 foxbody dyno'd on "X" dyno, and made 447. A cam only LS1 dyno'd on "Y" dyno, and made 367. Both of these cars are manuals, and from a low roll, the LS1 with 80rwhp LESS, pulled the fox??
A heads/cam/sprayed LS1 car was said to dyno 690 on "X" dyno. I raced this guy with my car making in the neighborhood of 575, and from a 35 roll to 120-125, took the win two times in a row by a couple cars?
Then the final deal, is a lil Ford Ranger making 504 on "X" dyno, and losing to my car when it had only bolt-ons, making 354/373?
Something VERY strange is going on, with the higher reading dyno more so than the other one, although, the dyno that I and my buddies have been on, seems to be reading significantly lower than it has in yrs past.
While my car was stock, and dyno "Y" was new, it laid down 321/331, and ran high 12s. Now this past weekend, my buddy dyno'd his near stock 01 m6 camaro, and it did 292, BUT, this car went high 12s as well, with the best run being 12.81@108ish. I did the calculations, and with the same 60fts, my car would have went 12.78 to his 12.81, so the power should be nearly identical, and I know we are very comparable drivers.
Then there was an 04 GTO m6, that only made 280ish rwhp, and went 13.2@104. This is just weird to me.
The last thing, would be my car. It dyno'd at 446/411 a lil over a yr ago at the same place. I went back this weekend with the 292rw car, and mine went 430
Yet it still runs the same?Now I understand dynos are only tuning devices, but what I am curious to know is how long is it until they need the calibrations checked? Or some re-calibrating, etc? How is that done?
The result of good tuning and dyno use is a fast time slip at the track, not a print out of what could be magic numbers.
Right On!Unfortunately, I never dyno'd on a jet, Mustang only, so I really cant compare #'s. Some say 10%, 12%, 15% not sure. Its obviously important that either be properly maintained & Calibrated.. But how do you know for sure? Thats why I like to back it up with @ the track.
It would seem to me that the best way to find out if all of that hard-earned and spent money was worth it is to dyno your car right before the installation/tune, and then right after on the same dyno.
Even track conditions and variables can change enough from day to day to not give you an accurate read on how much you gained (have to figure in driver, temp and humidity, track prep, etc, which all changes daily). Always baseline before the modification and then dyno right after on the same dyno if you are able.
Our dyno has been said to be high by many people on the internet because of the #s we produce, BUT the locals around here always seem to be a lil upset when they stop by for 3 pulls compared to some of the other dynos in the area.
Jim
Here's some personal instances I've encountered:
My car dynoed 333/345 with stock clutch and stock 16s. It now has a SPEC and 18" Z06s and 30k more miles. It would prob. dyno less but it traps 108mph vs. 105mph back when it it had the stock clutch and shitty tires on the 16s.
My best friend had a 347 fox that dynoed less than 400rwhp at the wheels(Bogarts and 28" ET Streets) and ran 6.8s in the 1/8th. On the 150 shot it made a tad bit over 500(can't remember exact numbers but it was between 500-525) and ran 6.08 and 9.55 in the 1/4.
Another one of my close friends had a 02 SS with a Vengeance 416 with TF225s that dyno'd 524rwhp with true duals, 6spd, 17x11 chrome ZR1s with 555Rs. 9" with 3.73s and steel DS. It went 7.35@101mph on a 1.8 60ft and granny shifting the ONE time it went down the track before he sold it. That was in a full weight fully optioned 02 SS on 17x11s with the shittiest drag radial you can run on a high HP car. It hurt a LOT of car's feelings that were making more "dyno hp", I can promise you that.
Dyno numbers ain't **** to REAL racers, they are for gettin' your **** running right so you can have a REAL number....a timeslip.
Even the most expensive barometers are calibrated monthly. I've seen good ones be off .030 of an inch a year. Add that to being off 10-20% in humidity, and now your SAE readings are off as much as 5-10%.
While there could be numerous factors involved, that would be my hunch how the same dyno would begin to have erroneous readings over time.
I like the before/after concept of dyno testing. At least on that particular day you are pretty much assured of the gain/loss results.
No dyno expert, but testing a few dyno's up here at Mile High on hot summer days and bringing my own weather station along..a few times I saw variations in their weather data that made readings about 4-5% off.
In essence track testing encounters the same dilemma. That track time may simply just reflect how much air got into your engine on that particular day, which depends on air temperature, pressure, humidity, driver ability etc..
Something to consider..WeathermanShawn..
Thanks for everyones replies so far.
