anybody have any opinions with the 78MM FAST intake VS the LS6 intake?
With minimal porting to a Fast 78 you can run a 85mm tb which will be a cheaper alternative to the Fast 90/90 and perform nearly as well. Used Fast 78 can be picked up cheap as well as the Professional Products 85mm throttlebodies.
I doubt the stock Fast 78 would gain over a LS6.
8 Sec Tuner
Ditto. THe 78mm FAST is a nice piece. We have done 2 Cam only LS6 Z06's with the FAST 78mm. And they are making about 20 more RWHP over cars with the same cam/mods running LS6 intakes.
We just did a 02 Z06 that made 447 RWHP with Kooks, vararam, cam, pulley, FAST 78mm through stock Z06 exhaust!
Out of the box will show 6-8 RWHP.....add 5-10 more for a ported version depending on the rest of the combo and who does the porting. A 90 mm is worth 5 more RWHP all else being equal and ALOT more throttle response and SOTP which makes part throttle operation alot more fun but doesn't change the fact peak numbers will only be about 5 RWHP different assuming both intakes are ported and that assumes a ported 78mm epoxied TB (not an unported 78 TB).
Hope this helps...
Tony
Hope this helps...
Tony
