Has anyone dyno'd the difference a head gasket change makes?
I'm wondering what the gains would be from going from a 0.060" head gasket to a 0.040" gasket. Assume no other changes and that PtoV clearance isn't an issue.
Before anyone screams that it isn't worth it, I've got head studs and can do the work myself, so it would cost me just the price of gaskets and my time, which I enjoy wrenching on the car. So if it gains me 15tq/15hp, I think that would be a great mod.
Maybe Lou, Ron, or Tony can chime in.
-Reducing the HG thickness by 0.020" will reduce the combustion chamber by around 3cc on a stock bore LS1. (0.006" per cc)
-According to this calculator, going from 0.060" gasket to 0.040" will increase SCR by 0.50.
http://www.c5frc.com/calculators/Com...Calculator.htm
-According to the calculator linked below, at 425hp and going from 10:1 to 10.5:1 you would gain around 5hp (~1%).
http://www.bgsoflex.com/crchange.html
I've just been going back and forth with swapping to a bigger cam, but my heads have been milled roughly 0.037, which raises some PtoV clearance issues, especially if I were to run a tighter head gasket.
-.006 to -.007 with a STOCK piston is the norm but a stroker or built motor can be all over the place depending a few things etc..
For instance lets assume u have +.004 deck height on a few 402's...So if I run the .053 gaskets it would be +.057 which IMO BLOWS....
U need to check the deck to find out which gasket u should run in relation to PTV..Brein u are correct on the assumption that the larger cams can bleed down cyl. psi and this is an easy way to push it back up and keep from loosing power..The DRC/SCR calcutaltor is a viable way of doing this along with some common engine tools...
The engine were doing for Tony as a matter of fact is running a .040 Cometic and after calculating the math this is a good balance...Its worth doin Brien but u need to do the math..Its also worth some power and in turn less chance for detonation
But hey all I do is babble about what cam I am putting in my car from day to day
Either way,If you go with a bigger Cam with more overlap it is good to raise the static compression.That does help alot.I just don't see spending the extra $$ on .040 gaskets instead of the .052 GM's.I know people would pay the $$ for a few hp but I see it as a dyno variation.
From what Tommy and Joe Prince said, I'd benefit going to a 228/232 cam, but I would have some concerns about piston to valve clearance, which then leads me to flycutting, which then hurts dynamic compression again.
Once I finish getting my tune squared away, I'm going to toss it on a dyno and see where I'm at. Maybe I'll just leave well enough alone till I decide to go bigger cubes or FI down the road.
