What should my upcoming h/c n2o combo run?
Next week Ill be ording a ms3 cam, prc stage 2.5 5.3 heads, built trans circle d 3800 stall and a ud pulley. It will be with a 150shot and some 275 mt dr's, any ideas? Im thinking 10.7-10.8 @126mph on the spray
Administrator
Sounds about right to me providing you can cut a 1.5-1.6 short time and not smoke the tires. 275 MT DR's are pretty small tires, but that auto will definitely help hook the power!
if you cut a 1.5 youll be able to hit 10.85, otherwise mid 11s... you gatta figure that you ran 12.4 with a 100 shot, with the extra 50 youll be at 12.1, so your banking on 1.2 seconds off from a big cam and heads, which with that setup is possible but youll need a perfect run
just me .02
just me .02
10.70s will be no problem if you can get it to hook with that combo.
My car is cam only on a 150 shot and has so far run a best of 10.92 @ 126 with a 1.58 60ft. I was running 275/40/17 BFG DRs.
Well an update on my car, I got the trans and stall in but had a problem with it holding fluid so its back at the trans shop. I have the heads and cam in my room waiting to go in, it will probably be a month or 2. I decided to get a ftra instead of the pulley and ordered some 275 mickeys that are at discount waiting on me to bring the car there. Also when I get it back I plan on doing some more weight reduction, already have !swaybar, !spare jack. I want to take out the rear seats, put in some light weight carpet, take out the hatch speakers, windshield fluid reservoir. I want to take out alot of weight but need to keep the a/c since my son rides in it sometimes
