Racing a "10 sec." Civic Hatchback...
Hey guys just wanted to get some opinions on how you guys think this will go down...I've been called out by a Turbo Civic who claims to be in the 10s. Haven't gotten much info. but all I know is that its a fully built Type R engine with sleeves and will be running 14psi. It's suppose to be street legal without a cage and wants to put down some $ on a run.
I have heads, cam, intake, full bolt-ons, 4400 Vigilante Converter, cut-out, 4.10 gears, et streets and a tune....I haven't been up against a Turbo Civic before so don't know what to expect. How do you guys think this will go from a roll or a dig...I'll be pushing for a dig race of course!
Ask him to go from a dig. If he doesn't want to, you know he's full of **** about the "10 second civic" part. If it really HAS RAN 10s before, he should be eager to go from a dig.
A built Type R block with 14 psi could give you a good run if he is full weight and has some suspension but if he's been taking weight out of his car you might wanna watch out
Meh whatever. Both cars will probably have traction issues on the street from a dig or low mph roll. It's hard to say how fast his car should be without knowing what turbo he has anyways.
As a comparision, my buddy's GSR swapped hatch with forged internals and a T3/T4 went 10.6 @ 131. He can drive the ******* **** out of that car though. If this guy's car is anything like that, I can't see a na heads/cam auto car staying anywhere near the civic from a roll.
i dont know how/what your car runs but, I dont see him wanting to run from a dig if hes on a street tire, he wont hook, if he comes out on a slick, it may hook(as well as a boosted fwd car will). However from a roll, you may be in trouble. Being a turbo car he is going to come on STRONG on the top end, where as with a stall that will not be a strong point for you.
Keep us posted man
Keep us posted man
no cage? To be running 10's in a civic I would think he needed alot of track time just to practice launching, and you don't run 10's without a cage. I call bull or that he's just guessing his time...
That's exactly what I was thinking....I bet there's at least an 80% chance that he's just guessing on his time and he's just talk. Well I'm definitely gonna run him but for no more than like $100 if the car looks legit....and if I do lose then I'm gonna have to bottle feed my TA so that I don't have to worry about this again
No idea to be honest, once its turbo'd anything can happen. Can be fast as a bullt or slow as a slug, all depends on the work REALLY done to it, which he probably won't reveal all to you. Deff. try and go from a dig though if it goes down.
Since he has the turbo, i say bolt up the sneaky pete just incase! Run the first one without it to get a good feel for how his car is performing. Then run him again no holds barred...
Most tracks don't care unless it's a race. I've ran 11s at a few tracks and haven't even been questioned about wearing a helmet. So it is entirely possible to run tens without a cage.
I would imagine he will have traction problems in at least 1st and maybe 2nd also, that is where you need to pull him hard.
like people are saying, it also depends on how its built. I know my good buddy I race with has a 95 4-door civic, with a single cam(much less hp than the DOHC type R), small turbo (off an evo 3), ebay turbo manifold, full exhaust, full interior, stock cam, stock intake mani, and the car ran 12.8s in street trim, 15psi, pump gas, on a drag radial.
If he knows what he is doing it could be very fast, but then again, you never know. Traction will be your friend
If it is a sleeved block, I wouldnt trust its only on 14psi. I know people with similar set ups pushing 500whp
This is Phoenix...land of sandbaging, and bs. This could vary well be the real deal, or he could be trying to bluff you out. Ask for money, claim to be fast, you punk out, you = bitch. Then you put your money up, he could punk out...or he would take that **** and run. I say, hit it with a good sized pill, and take his money.
There are some 10 second civic turbos out there..I have heard of them in my city but haven't actually found one yet..at least not on the street. To hook a 10 second fwd pretty much need slicks.Even nittos doubt would cut it. FWD is bitch to hook .Had a few fwd turbo talons..awd is much much better in the hooking up high power department.
You have et streets. Go from dig only. And boost level is meaningless number without knowing what turbo he has. Bigger turbos might make 500rwhp at 14psi. Smaller one can make 200. Huge difference for same psi.
Also wondering why he would run such low boost. Most turbos that you would put on to turn 10s would be spun a lot higher like 25psi. And its easy to turn up boost way higher in car with electronic control at touch of a button. He could be at 14psi for a play around pass and then at 25psi on race for his real pass. If he has a brain he can make racefuel easily with xylene or toluene. Or can run alc injection to run much higher boost on pump gas.
I say run this guy for 100 whatever..He is also a stick and will likely blow the race anyway. You are auto can't miss shifts if you let the car do the shifting. Autos make the best 1/4 mile car. I beat a turboed nitroused civic at track with my 14.2 near stock 96z vert. He was on street tires! LOL his 60ft was 2.85. He nearly hit the wall and his mph was 85mph since he had to get out of it and he couldn't shift for crap.
Remember though from a roll more dangerous and you can lose to one of my turbo cars one race and then I just punch up the boost and waste you like you had a 4 banger.
Thats what makes turbo cars so fun.Dial up the power when you want it ,assuming you have the supporting mods, built engine tuning knowledge etc to handle the higher boost and power.
You need a spot. You need a ET ticket. Tell the *** clown you'll pay to get his car on a drag strip. When it goes through tech tell them it runs 13's. If it runs 10's he'll get kicked off. On street tires no firggen way..
Jakes Dad
