hp numbers
hp numbers
i just swaped out my cam and put in an ms3 cam and longtube pacesetters with no cats and a cat back its all 3in but to a crappy flowmaster 80s series had to quiet it dwn ahahha
i was wondering how much hp i would put dwn to the real wheel ive seen people put dwn 400 to the wheel and that was my goal would that be possible wiith the mods i have?
i also have a fast 92mm and throttle body i havent installed yet wouuld that push me too 400 or no? just wondering cause that was my goal.....
i want 400 to the wheel lol
You should be right at 400 with the ls1 but good power gains if you get the ls6 intake and the prc 2.5 are good heads it put my friend at 432 rwhp with a 228r cam and he has the ls6. i would run the fast or at least the ls6 because your stock intake drops off at high rpm and you having the ms3. If you want a cheap budget build get the 241 heads and ls6 intake and mil the heads a bit not to much and you will max out the ls6 intake (only good for 440rwhp) also get 30pd injectors.. Only good number come from the ms3
