what do you think it will put down???
347 ci. ls1
11.9:1 cr
ls1 crank
ls1 rods
arp main studs
arp rod bolts
mahle rings
manley 3.905 forged pistons,coated skirts, -4cc reliefs
trick flow .045 gaskets
prc 5.3 stage 2.5 heads, cnc ported, them fully hand done. largerseats with 2.05 ferrea intake valves and manley 1.600 exhaust. milled to 58cc. flow 350 cfm @ .600
prc dual springs
all ti. hardware up top.
248/254 .620/.612 113+3lsa
ported ls2 intake, port matched to heads
92 mm tb, matched to intake.
85mm lid & k&n filter
stainless 1 7/8 headers
3" ory
corsa catback
175 dry shot, hidden halo kit
built 4l60e
vette parts, steels ect.
ptc 3600 lockup converter, will be locked.
aluminum drive shaft
3.23 gear in stock 10 bolt
26.5" tire on aluminum wheels
what will it put down?
11.9:1 cr
ls1 crank
ls1 rods
arp main studs
arp rod bolts
mahle rings
prc dual springs
3" ory
corsa catback
built 4l60e
I don't think u read carefully. Lol I hope u mean n/a.
But I can say the same setup u just cnc port. No hand port. Smaller valves. Only 10.5:1 compression. No spray. and only on 7 cylinders w a unlocked convertor put down 394/408. I'm hoping this setup does close to 500 n/a
yep..that's N/A at the crank. Get me the full flow table from the heads and I'll get a better number. The numbers are coming from Engine Analyzer Pro 3.9. The more accurate the data, the better estimate you'll get.
Ok...I re-read your build specs once again. Something doesn't add up...58cc chambers with an .045 head gasket assuming "0" deck height and -4cc pistons does not add up to 11.9:1. It's 11.04:1. Anyway, I tweaked the configuration and used everything you listed. I used a flow table from the PRC website on those heads minus the hand porting.
487HP@6000
474TQ@5000
487HP@6000
474TQ@5000
487HP@6000
474TQ@5000
487HP@6000
474TQ@5000
theyre actually 56cc chambers, and why did u figue 0 deck height? its about -.008"
Just making assumptions....Ok...It's about 11.6 not going to account for much.When will this motor be done? I am curious to see what the actual numbers wind up being. I've been using EAP for awhile now and it's been pretty accurate.
