hitting the track friday what u guys thing ill run!!!
99 t/a gutted: no ac, no ps, no carpet, gutted dash, gutted headlights, using fogs, no back seat. t-top car.
motor and trans mods: lq9 6.0L 241 ported polished milled heads approx 11.0:1 cr. ms3 cam. victor jr efi, edelbrock low pro elbow, ported stock tb, no maf, ebay headers, stock injectors, under drive pulley. built atf th400 t-brake revers pattern manual valve body.
suspension basically stock. 90/10 front shocks, qa1 rear single adjustable shocks, lower control arms, pan hard bar, relocation brackets, 3.90 gear, stock diff...
i stopped weighing parts at 300 pounds so id say with the new plastic seats and the rest of the parts would be around 500 and not counting the added weight of the iron block
what u guys thing id run 1/8 mile at the strip this weekend
thanks in advanced
thanks in advanced
6.9x maybe 6.8x is what im hoping for if the track is prepped right and they didn't feel lazy when prepping it. i should be good. im running 28x10.5 hoosiers dr so hooking shouldn't be an issue. wont try the t-brake till i get a new diff witch is what im dying to used lol
thanks guys for ur input so far
went 7.4 before with the ls1 only things changed was went from 5k converter to 3800 nitrous one and from true duals to tsp y pipe and 7.60 !!! went slower i don't know if its the exhaust or the converter and i was coming off the line with the trans brake at 4k. and with the ls1 was on foot brake. what do u guys think.
