Tips to beat 2011 5.0 coyote
I would like some tips to beat a bolt on/ straight pipe 2011 5.0 coyote. He got me pretty good at a 40 roll. He is standard I'm a built a4. I have a ls1 with slp lid, 1 3/4 long tubes, 3" ory pipe straight pipe. Stock converter, stock rear gears, texas speed 230/236 113lsa cam. Tuned by khp. Stock heads and intake still. Next run we will be running from a dig 0 to 100 for couple hundred dollars.
Moderator
Received 1,838 Likes
Higher stall converter will be the single best upgrade with your current list. Around 3600 stall should do great
You need more stall than 3200.
How high are you spinning your motor?
I would go with a 4000 stall. With 3.73's it will be perfect.
If you want to win that race go with a 4000 and a set of Hoosier Dr2 radials and that race will be over before it started.
