Prc ls6 stage 2.5 results
Alright, i know i personally hate when i find a thread where someone does a before and after but its not a apples to apples comparison.
this is a true comparison. No other changes beside the prc 2.5 ls6 heads.
I picked up 26whp and 24ftlb torque throughout the whole rpm band. The car before had STOCK 243 heads already.
this is a 140k mile LS1 with a tick stage 2 cam, home ported fast 92, pacesetter longtubes and y pipe, slp lm1, 4l60e yank ss3600, 10bolt 3.23, 26 tire. Speed density, ftp lid, chrs1313 nonac
I wonder if the plugs really make any difference in the numbers though. When i went to the br7's my car felt exactly the same in every aspect. How much are you spraying?
I keep harping on my reason for saying the above. You have an "A Typical' TQ curve, where TQ starts up nicely, then "Flatlines" and starts dying to soon.
First time Tq peaked at 4750 RPM.
Replaced heads that flow more air and Tq peaked even earlier at around 4600 RPM.
Simple reason your haven't tapped the power potential of either build. That "Y" pipe can't meet the flow needed to support either build.
Look at any Dyno sheet where "Y" pipe is listed as exhaust and you'll see Tq dying off an start to fall off rapidly in the same RPM range as your build, instead of slowly and carrying HP higher than it's around 6300 RPM peak now.
Swap out that "Y' pipe for a 3.0" TD system with good flowing mufflers. If that's not practical for your car or pocket book, then at least install 3.0" dump valve on each header, and let your engine/air pump breathe.
Loved to see how either of those effects the engine TQ curve and how that effects your HP Peak.
There is a lot of Hp/Tq left on the table with your engine.
Poor house is correct, exhaust is your bottleneck. This engine should have 1 7/8 primaries and true duals. With a retune, you will pick up hp and tq everywhere - I would bet another 25-30 across the curve, maybe more. Don't buy into the backpressure argument, these need to breathe especially yours. Nice before and after, you are absolutely right on apples:apples.
