1998 SS, HP est?
ls6 out of a 2002 z06- ~80k on motor
ported 853 heads
ls6 intake
comp .570/.534 118 separation unsure of duration
3" x pipe axle dump
K&N FIPK w/ SSRA mega mouth
85mm ported maf
92mm holley sniper tb
1 3/4 long tubes
shift kit/2400 stall 4l60e
d585 coils
underdrive pulley
shop i bought it from guessed 360-380, does that seem about right?
ported 853 heads
ls6 intake
3" x pipe axle dump
85mm ported maf
1 3/4 long tubes
d585 coils
underdrive pulley
You should find out the duration if possible. Lift means relatively little compared to duration.
The following users liked this post:
KW Baraka (03-30-2022)
Look thru the Comp LS cam catalog and see which cams have the lift and LSA you stated.
Funny how the EXACT lift and LSA numbers are stated but the most important ones are in the wind??
You dumped the 243 heads that all LS6's come with for 853's?? Backward move. Even ported, the port shape is not as smooth as that of the 243.
The 92mm TB gains nothing as the inlet of the LS6 manifold is 75mm. That will limit flow to what the OEM 78mm TB already does.
Any real gains will be from the headers/exhaust system and the unknown cam.
G Atsma (03-30-2022)
ported 853 heads
ls6 intake
3" x pipe axle dump
85mm ported maf
1 3/4 long tubes
d585 coils
underdrive pulley
ported 853 heads
ls6 intake
3" x pipe axle dump
85mm ported maf
1 3/4 long tubes
d585 coils
underdrive pulley
Did the shop selling you the engine put it together?
360 to 380 is spot on see my signature
