Enclosed 28ft Race Trailer
1997 Pace American Enclosed Race Trailer Dual Axles / 28 Feet Long
Multiple trailer organizers and trailer shelving all custom aluminum to hold tie downs, fuel cells, oil, air lines, straps and all other necessary equiptment.
Rear pull down door with 8 foot aluminum extensions, for low clearance vehicles.
Full size fold down bed, screened roof vent, Central heat and A/C.
Has full size side door for easy access.
Brand new slide out guardian generator with custom fuel cell mounted underneath, also comes with a 50 foot cord for electrical if you do not want to run the generator.
New tires, New Spare tire, Has rack to hold additional tires
New floor, all new diamond plate, and aluminum angle
Multiple position tie downs
3000lb Wench
Overhead and outside lighting.
Up front cabinents and counter space.
Comes with a Craftsman tops tool box (8 drawers).
Small mounted air compressor 125 psi, custom drain mounted under trailer.
Holder and spare tire drive on / transmission holder.
Comes with custom aluminum wheel chucks.
Custom Breaker Box
Front hitch assembly is power so you can lower and raise trailer on and off .
Adjustable class 4 hitch, 2 5/16th ball, anti-sway bars, leveling bars.
THIS IS A 100% FULLY LOADED RACE TRAILER
$12,000.00 OR BEST OFFER
CONTACT WAYNE AT 215-669-7684
http://s730.photobucket.com/albums/ww306/pontf67/
3000lb Wench
Custom Breaker Box
Here are the pictures you requested, some pictures need to be rotated. You can also zoom in to see serial numbers and model numbers. Once again if you need delivery or we can meet somewhere in the middle.
Thanks
Wayne
215-669-7684
Thanks
Wayne
215-669-7684
Got e-mail and call check your in baskets. The generator cost me almost $4,000 with the junction box, breakers wiring and jumper cable to use outside power as well if you ran out of gas. But it does say O.B.O. and fully loaded with everything.. All the shelving and all the other misc. aluminun shelving and holders will add up quick.
Thanks
Wayne Marshall
Thanks
Wayne Marshall
Actual weight as it sits is approx 3000lbs loaded with the goodies, it has two torstion five thousand pound axles which can handle a gvw of 10,000 lbs, trailer pulls straight and is very clean as you can see by the pictures, thanks for your interest. If thats your vette in the pic, nice. Thanks.
Also Im willing to deliver if needed.
more pics sent and delivery is no problem all I'll want in return is just fuel $$$ nothing else very reasonable.. Hope to answer all your questrions and meeting you in person as well
Thanks again
Wayne Marshall
215-669-7684
Thanks again
Wayne Marshall
215-669-7684
