HELP!!! Philly area, I need help removing a pilot bearing.
I cant get the pilot bearing out of the crank. I have tried the grease trick, a pilot bearing puller, and a blind hole puller. I have soaked the area with PB plaster and nothing, just tired arms.
Does anyone have something better I can use? I will pay you for renting the tool and your time. Beers on me if you can help, the car is on stands in my tiny garage.
I have always used a pilot bearing puller or a slide hammer with a small hook on it. Never use the grease method on the lsx cranks. They have a metal plug in the back of the crank that will get knocked into the oil pan if you hammer in on it.
My pilot bearing was stuck in there good. I used a dremel to carefully cut into it and weaken it. Then I cracked it with a hammer and chisel and it came right out.
I found this picture of a real pilot bearing puller, not sure where to get it though:
![](http://i275.photobucket.com/albums/jj282/marklsx/car/LS7%20clutch/pilot_puller.jpg)
Like highflyin said, bad idea with the grease method. You should replace the oil seal plug after you get the bearing out.
If all else fails you can weld a bolt to the stock metal bearing and use the threads to pull it out by placing a large socket over the bolt and installing a nut and washer to tighten and pull the bearing out.
