Nj Inspection Question
I have been debating over getting A Cat y Pipe or a regular one the only thing that is stopping me with the Catted Y pipe is the freaking Price... If i put in 02 sims and the engine light is not on then i will pass correct. if anyone has any suggestions please let me know Thanks all
I would skip the O2 sims and just have the codes deleted/turned off in the computer.
As for the Y-pipe, I live and Jersey and went through a state inspection facility last October and my Y-pipe has gutted cats and I have a block off plate/dump just before the over-axle pipe and it passed first try. They plugged the car in and it came up clean. They did look under the car very closely, because it smelled rich (gutted cats will do that) but saw the shells and away I went. Would I recommend this, no. Get a catted Y-pipe and you'll never have to worry.
State facilities in NJ vary greatly because every person has a different motivation level and agenda. Some people go for every little detail, others are just punching a clock and look only for the "big stuff". Its hit and miss.
Good luck
Good luck
you wont lose much power with a pair of high-flow cats. and even if you do, youre probably talking a handful of rwhp, rather then failing inspection, having to pay to get it passed; or worse, getting tickets or god knows what else if youre caught with a fake sticker or an illegal inspection. just buy the cats and dont worry about it. if it was an all-out racecar where every single HP counted, you wouldnt be driving it on the streets to begin with.
You never know what you are going to get until you get there!!
In fact this can change within the same facility depending on who is working that day/hour/minute!
Given NO codes/lights, people have gone through without even having cat shells welded onto their off road ys (or gutted cats welded in).
Whereas one year they tried to fail me on a visual because the f'ing idiots could not find my legal, stock, OEM driver's side cat in the STOCK location!!!!.
So, EVEN with no codes/lights, and a catted y pipe off of LTs, there is still the possibility of them failing you.
![Sad](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_sad.gif)
Best advice, get the cat back of your liking a good set of headers and catted Y....and be done with it.
1 Post
Good luck
Good luck
Exactly true! This young dude that was smiling from ear to ear when he was testing my Vette failed me because the E-Brake has to be all the way up to stop the car from rolling
![Icon Rolleyes](https://ls1tech.com/forums/images/smilies2/icon_rolleyes.gif)
