project tin can shootin for 9's
Old Feb 24, 2016 | 07:19 PM
  #981
Taubr Unit's Avatar
Made some travel limiters to help out my 60'. Pretty basic set-up as everyone else...
Then i was board so i figure id cut some thick aluminum washers for my intake. You guys with a vic jr/sr prob know that the intake holes on them are huge, way bigger then they need to be and that annoyed me. So i cut some thick washers on the lathe so now i dont need to run a ghetto 2-washer system and have them bend inwards...
Next mod was to baffle my valley cover for my catch can lines. LIttle did i know the openings in the block were in front and in back, so not knowing that i welded my -10 bungs directly over those openings so i got a lot of oil pushed into my can. Took off valley cover, welded on bungs so hopefully this helps divert oil away and back down into motor vs in can.
Lastly is my parachute mount i got from RSM. Nice little xmas gift from the g/f so that was pretty badass to have on xmas!, lol.
Old Feb 24, 2016 | 07:41 PM
  #982
mshadow's Avatar
Anymore pics of the mount did you have to notch the plate?
Old Feb 24, 2016 | 08:16 PM
  #983
Taubr Unit's Avatar
No more pics, had to notch the very top of the plate by a half circle, about the size of your thumb. Disconnected you prob couldn't even tell.
Old Feb 26, 2016 | 11:50 AM
  #984
overhere's Avatar
what size did you make the aluminum washers? also what size is the intake bolt? thanks.
Old Feb 26, 2016 | 01:37 PM
  #985
Taubr Unit's Avatar
The bolt I believe is a m5x1.0, the washer hole is slightly larger and 1/8 thick and about as round as a quarter.
Old May 14, 2016 | 02:52 PM
  #986
Taubr Unit's Avatar
Time for some updating. Since adding the parachute stuff i had to offset the weight somewhere so i took out factory seats and tossed in a pair of kirkeys and cut out the rear corner bracing behind the rear seats. After drilling a ton of spot welds those came out, not sure how much overall but enough to be satisfied.
Old May 14, 2016 | 02:58 PM
  #987
Taubr Unit's Avatar
As for power for new/bigger turbo i took out my old smaller blower cam from 2007 and went with a BTR stage 2 for more modern cam technology and power. Then re scaled the car and for a face lift i painted my convo pros black. Looks like a whole new car compared to when i started this thread back in 2006, lol. Next is a retune for 100oct and new cam/turbo then go chase that 8 sec time slip!!
Old May 14, 2016 | 07:14 PM
  #988
Zmg00camaross's Avatar
Looks good, like all the new stuff! I like the wheels black also.
Old May 15, 2016 | 07:35 PM
  #989
boss79z's Avatar
Looks good!
Old May 15, 2016 | 08:57 PM
  #990
JL ws-6's Avatar
Race your car!
Those wheels blacked out are a 1000 times better looking
Old May 17, 2016 | 06:05 PM
  #991
Taubr Unit's Avatar
Yea they do JL, not soo mullet anymore, lol.
Old May 18, 2016 | 01:22 PM
  #992
JL ws-6's Avatar
Race your car!
Exactly but I didn't wanna say it lol
Old May 18, 2016 | 02:23 PM
  #993
Taubr Unit's Avatar
It's all in good fun, lol. I can't justify $1000+ for a new set of wheels when for a little bit more I can buy a shirt block and go way faster then a new set of wheels would.
Old May 18, 2016 | 03:25 PM
  #994
abern310's Avatar
+1 on that! looking awesome
are those fronts shorter than the prior wheels? that stance is super aggressive looking now
Old May 18, 2016 | 04:27 PM
  #995
Taubr Unit's Avatar
Thanks, yea they are shorter. I went from a 27.5" tall down to a 26" tall tire on front. The 27.5"s were cool because you could tuck tire and close the wheel well gap and still have good ground clearance but they would hit the bumper cover so I had to step it down a size.
Old May 19, 2016 | 07:14 AM
  #996
JL ws-6's Avatar
Race your car!
Originally Posted by Taubr Unit
It's all in good fun, lol. I can't justify $1000+ for a new set of wheels when for a little bit more I can buy a shirt block and go way faster thean a new set of wheels would.
I get that. The sander wheels I bought for my car aren't the latest hottest looking wheel either but with a slathering of polish and a power ball they're not too bad.... Price was right and at the end of the day they're a double beadlock rear so how bad can they be.
Would I like a 2500 set of weld's on the car sure but I'm not doing that, I'd take that and add it to what I could sell my 2.1/1.4/1 th400 for and build a new Sfi case based 400, or a 1.58 first glide.
Old May 19, 2016 | 11:33 AM
  #997
Taubr Unit's Avatar
Yea exactly! I need a new center section and axles next. I have a 31 spline spool and Strange's "street" axles, not even their "street/strip" axles, lol. So a good aluminum bolt-through center, 35 spline axles are next.
Old May 19, 2016 | 11:48 AM
  #998
mshadow's Avatar
3109 with you?
Old May 19, 2016 | 11:53 AM
  #999
Taubr Unit's Avatar
Correct
Old May 19, 2016 | 11:30 PM
  #1000
JL ws-6's Avatar
Race your car!
I hear ya my rear has a set of very narrowed 33 spline moser axles in it, going to put some gun drilled/lightened 35 spline axles and put a set of 4.10 pro gears in the rear, along with a lw steel spool unless I find an aluminum one.
Going to have microblue coat all the bearings and gearset to try to reduce drag. May or may not be worth anything but my goals are lofty for this thing and if it does help, I'll take it.
If it ever proves to be too much for the braced up 12 bolt housing I'm going to have a chromoly housing done and the lightest possible options done with it, likely a full floater as well so I never have to think about it again.
Be a nice 7000 bucks to build that.
