Vortech Head Unit clocking
Old Feb 13, 2009 | 03:58 PM
Superman09's Avatar
LS1Tech Sponsor
Default Vortech Head Unit clocking
Posting a question for a friend. He is going to buy a vortech kit for his '99 SS off a local guy in town. He wants to ditch the aftercooler and do a FMIC. With this, he wants to know if the f-body head unit/bracket is clockable so he can best fit piping for a FMIC? That is all! We both called Vortech directly in which we were both put on hold until we reached an answering machine.... awesome! Thanks!
__________________
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
Old Feb 13, 2009 | 04:27 PM
ak95ta's Avatar
The gearbox is not clockable, but the compressor housing is. You can spin it ant direction you wish.
Old Feb 13, 2009 | 05:54 PM
John Milner 810's Avatar
is this possible? on the top left pic i want where the x is, to be where the other x is....if thats not to dumb sounding. haha.
and on the underhood pic thats an example of the way i want it to rotate. is this possible?
Old Feb 13, 2009 | 05:59 PM
Superman09's Avatar
LS1Tech Sponsor
From what I've been looking up, I'm pretty sure this bitch will clock any way you want. To get it where the X is and be facing straight down won't work though because of the side of the outlet on the blower. If you flipped it backwards which is not possible, then it would go there, haha
__________________
Old Feb 13, 2009 | 10:04 PM
DeltaT's Avatar
You may need to remove the entire unit and try different positions until you find one that will work. I think I see what you are trying to do - if the current outlet is clocked at 9 o'clock, you want it to be around 5 o'clock, pointing a little down and to the right, correct?
I don't know the V-9 unit, but I suspect the volute (compressor housing) is held on the same way as my V-2, with metal plates attached at both ends with a screw. On the V-2, Vortech puts extra holes so if you clock it, you can always find an assortment of holes (3 pairs needed IIRC) that will retain the volute. Be careful when you spin the housing. If it doesn't move, check again that nothing is in the way, and no bolts are banging up against something. If it still won't move, try heating the volute with a blowdryer, sometimes that's enough to expand them and free it up. If that fails, try removing the head unit and finding out what's up.
Jim
Old Feb 13, 2009 | 10:14 PM
YSILT1's Avatar
The V-9 supercharger actually uses a V-clamp. It can be adjusted 360 degrees. Just like most turbo housings.
Old Feb 13, 2009 | 10:48 PM
DeltaT's Avatar
Even better.
Jim
Old Feb 13, 2009 | 11:42 PM
'Trust''s Avatar
I don't see it working, it looks like it would be in the way of the tensioner/power steering pump. Why not just install an air-water cooler. http://www.vortechsuperchargers.com/view.php?pcat=3 or does it have one already? I don't remember.
Old Feb 13, 2009 | 11:55 PM
Mean Green z28's Avatar
Why clock it? Would something like this work under the SS hood? (I know it did under a WS6 hood; with a bit of cutting).
More pics if you click on it or the link in my sig. to custom installs
Old Feb 14, 2009 | 12:07 AM
'Trust''s Avatar
That's a pretty clean setup!
Old Feb 14, 2009 | 04:02 PM
its already got one, im trying to get away from that, id rather do a FMIC, the other its too busy under the hood the way it comes, and like i said i think i would like a FMIC better.
thats a clean setup, and i was thinking about something like that, but i dont know if it will clear the ss hood. and im not changing hoods. lol. thanks for the suggestion i will look into it.
Old Feb 15, 2009 | 02:42 AM
DeltaT's Avatar
Clocking can be useful though and is always worth consideration. Mine's not an F-bod, but clocking straight down on my V-2 T-trim, I was able to eliminate a lot of piping length and clutter to/from the FMIC:
Jim
