My 91mm turbo kit
My transmission is a powerglide with a ringless billet input shaft so it doesn't pump through the cooler ports. So for the trnsmission cooling I tapped the pan with an inlet and outlet for a cooler loop and a temperature probe for a thermostat. I bought a small gear pump,cooler and fan and mounted it in the back of the car with the fuel pump. The system is always hot and will cool the trans in the pits between runs. Its adjustable between 90* and 210*
I saw your update, It got me to post some pics LOL. I have been spending every spare moment I have on this pig. I hope to make some noise before to much longer
was thinking the same thing to myself. Which just reinforces the fact that I need to spend more time behind the torch - those things are sweet.
