LS2 APS w/ lg turbos
#183
got these done this week. trying to get everything ready to go back together
http://i866.photobucket.com/albums/a...d/100_9671.jpg
http://i866.photobucket.com/albums/a...d/100_9672.jpg
![Mr. Cool](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cool.gif)
#188
few pics from today
looks like i have .0015 to much wall clearance for my pistons. but it will have to do until told other wise. but i start checking stuff out to day. i took tthe day off work just to start putting it together. ive been waiting a year now and will not wait anymore
this is the back of my buddys shop. he is do kind to give me a place to work
![](http://i866.photobucket.com/albums/ab226/turboz28/100_9673.jpg)
JE pistons on howard rods and the are drity as hell. im going to spend a hour with each of them![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
![](http://i866.photobucket.com/albums/ab226/turboz28/100_9674.jpg)
new marks from something and they are deep as hell. im making some calls about this one.![MAD](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_mad.gif)
![](http://i866.photobucket.com/albums/ab226/turboz28/100_9675.jpg)
#192
SO this is what ive got done so far this week.
got the piston clean which took 8 hours for all of them
![](http://i866.photobucket.com/albums/ab226/turboz28/Engine%20build/100_9677.jpg)
this is the brush i used to clean the rings and ring lands out.i t work out well
![](http://i866.photobucket.com/albums/ab226/turboz28/Engine%20build/100_9676.jpg)
block got brake cleaned like crazy in all of the oil galleys and a good old air blow gun
![](http://i866.photobucket.com/albums/ab226/turboz28/Engine%20build/100_9678.jpg)
callies crank
![](http://i866.photobucket.com/albums/ab226/turboz28/Engine%20build/100_9679.jpg)
putting it all together
![](http://i866.photobucket.com/albums/ab226/turboz28/Engine%20build/100_9680.jpg)
![](http://i866.photobucket.com/albums/ab226/turboz28/Engine%20build/100_9681.jpg)
checking end play
![](http://i866.photobucket.com/albums/ab226/turboz28/Engine%20build/100_9683.jpg)
i hope to have all the pistons in this weekend. The oil clearances on the crank are .002 and .003 on the rods. the piston to CYL. wall is .0075 which is alittle big but .009 is the max for these piston. they are race piston made for alot boost and heat so they should grow alot![Burnout](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_burnout.gif)
ill keep you all up to date until the end of this one
callies crank
checking end play
#195
well made some more good head way on the engine today. i need to track down a few small things. The heads need the valves taken out and clean, then they can go on.
also got my ATI super damper today. NIB for 375 off a tech member, stock size,steel with a/c pulley. you can see the junk APS under drive pulley in the pic
![](http://i866.photobucket.com/albums/ab226/turboz28/Engine%20build/100_9688.jpg)
my buudy mike has been helping out the last few days. thanks mike
![](http://i866.photobucket.com/albums/ab226/turboz28/Engine%20build/100_9690.jpg)
got the pistons in after we plastic gauge them man that takes some time
![](http://i866.photobucket.com/albums/ab226/turboz28/Engine%20build/100_9689.jpg)
then alot of small things
![](http://i866.photobucket.com/albums/ab226/turboz28/Engine%20build/100_9691.jpg)
#199
AFR is a great head. ERL and AFR both said i will be fine pushing 18psi with 4bolt head.
now maybe i should ahve done it so i dont have to take it apart to have it redone. but if it gets to that point. i will pull motor. put it in my Bros car and build a 427. but GT35r turbos first. i think i got this figured out. i will post pictures later.
#200
well uless you can show me a reason for 6 bolts per cly wtih an AFR build. then i dont see why it is bad.
