The EPP Forced Inductions Cam
This question is more pointed at Exotic Performance Plus, but does anyone have any idea how much h/p the EPP forced inductions cam produced on a supercharged or turboed setup on an LS-1, or an LS-2 motor, with stock internals?
Scroll to the bottom on my videos here: http://www.tunedbyfrost.com/video.htm
Twin turbo vette, stock bottom end with truck heads and a TTi X-kit (twin turbos)
The cam is only one small aspect of an engine setup. Cams themselves do not produce power, so the question is more than a little vague.
While I think that this cam works well in a matched setup, ANY car will have good gains with an aftermarket cam and springs and a centrifugal blower... The stock setup doesn't allow you to spin it past 6200; just adding room up top to turn the engine raises peak HP significantly.
http://www.exoticperformanceplus.com...Car.php?car=59
Check out the above Corvette C6, which has heads and exhaust, ProCharger at 8 psi and our blower camshaft. Stock bottom end and it is making 671 rwhp with timing pulled out of it to try to keep it alive. Bob
