Fireball Outlaw Drag Radial Rebuild Thread
#369
Thats cool, so no supports to the bumper? Thats a nice looking piece! I have a Camaro and the only wing out there I can find that has no bumper supports is the racecraft wing. I like that carbon wing better, but 20 weeks, thats how long KB took to make my block...
#372
Race your car!
At what point is an intercooler that big really needed? I mean I saw one in a 69 camaro last weekend with a gear driven F3 procharger on it with a BBC. It had to be making some BIG steam, the one pass I saw it run it went 4.68 @ like 168 or something nuts like that.
I think the intercooler is going inside my car... probably behind the passenger's seat. Just not sure at what point one that big is really needed.
Also.. I've asked before, but never got an answer, at what point is the charge pipe need to be 3.5 to 4 inch, and at what point is the total overall length of the charge pipes become an issue, or does it? While I'm asking... can you step up from the blower outlet, say if it's 3 inch can I go to 3.5 without causing a problem, ir should that remain the same as the blower?
Educate me please
Educate me please
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
#373
7 Second Club
Educate me please![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
Educate me please
#374
Race your car!
So what is the preferance, or is it application specific?
Sounds like I'd be o.k. with the newer style ones, just get one for a little higher power level then I need, I don't expect to break the 1500 hp mark, so that being said one with a 2000 hp capacity, probably plenty with the newer style cooler?
What abotu water capacity? 5 gallons enough, that enough room for enough ice for a run or 2(drain the water and refill with ice once back in the pits after every run I figured)
#376
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
got a little bit more done...
fabbed up some mounts to support the front of the intercooler (its now complete)
![](http://home.comcast.net/~tfranklin5580/newIC4.jpg)
trimmed some areas on the wing to make it fit the car better (so I can use piano hinge to mount to the car). Also located the rear wicker and have it partially installed
![](http://home.comcast.net/~tfranklin5580/wing2.jpg)
#377
#378
got just a little bit done this weekend...
got the windshield gussets finish welded...this should 100% wrap up the cage stuff...just need to get it certified now
mounted the wing to the car...still need to order the wing struts and dual parachute mount stuff.
I'm kinda intrigued with summit racing's new line of basecoat/clearcoat paint system...Up to now I've only shot PPG and Dupont...but I'm thinking of giving this stuff a try...I really like this color they offer "Killer Gray". The whole system (primer, color, clear + reducers and activators) is only ~500 bux
![](https://static.summitracing.com/global/images/prod/large/shz-swbc522v_w.jpg)
#379
Race your car!
All you need to do is call someone like Chiseled or sponsors, they will set you up. 5 gal. tank is good, and a tranny cooler while your at it. I believe in going bigger than you need, leave room to grow. The pipe length, I have seen it all the way to the trunk with no issue, you might lose a little more boost. In general, the A2W with 4" pipe doesn't really lose to much, I think I remember around a pound or so with it in the passenger seat.
What about tubing size, at what point is the 4 inch tubing needed vs say 3.5 or 4? what if the blower outlet is smaller tehn 4 inch, will it screw things up to bump it up to 4 inch?
#380
you're just adding some volume...won't screw anything up...my old setup was 3.5" out I ran 3.5" piping to the I/C and 4" piping from the I/C to the TB
