Fireball Outlaw Drag Radial Rebuild Thread
#507
maybe its just me but wont the passenger side pipe get squashed when the car comes down just after the launch? just inboard of the strut, it looks like maybe a k member bolt? right on top of the DP, when the lower A arm comes up it may pinch it
#510
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
I may notch the pipes a touch in that area to buy a little more room. Luckily its near the pivot point so it doesn't move "that much"
#511
the shock tower (especially with the strut bar) adds structure to the front frame...probably would take just as much weight to do what you are thinking and it would be rather difficult to make sufficiently strong...
#512
there's a fair amount of room there...I have the pipes lifted as far as possible...GM didn't design that space for a 4" pipe to run thru ![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
i didnt think i could fit a 4" pipe through there, but if you can, wow, might try that.
can you turn your wheels, lock to lock and not hit the pipe?
keep us posted when you get it running and let us know if your suspension hits the pipe when it loads/unloads.
any more pictures showing the clearance to the suspension
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
#513
i was thinking of doing something similar when i redo my turbo kit.
any more pictures showing the clearance to the suspension![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
you can not go lock-to-lock with my madman rack (not sure if its the same as stock). I don't need to be able to go that far anyway...spool + radials don' like super hard turns
![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
I need to adjust the ride height and see what clearance I have left over. I haven't been able to fully test it yet since I have some old tabs from a previous travel limiter in that area....Once I cut them off I'll use some straps and try to get the car to full compression to see where I'm at. I may build a bump stop for the upper control arm just in case. If the car aims for the sky though...all bets are off
#515
well i do remember the twin 88 ODR car LMR ran at the 2009 LSX Shootout had a pipe through there and after ther test and tune it had dents in it, im sure its not a big deal i just wanted to point it out in case you hadnt seen it. something to keep an eye on i suppose
#517
luckily dual 4s provide about 28% more x-sectional area than a single 5 so some bangs and dents will not hurt overall flow. this will still be miles better than the single 4" that I ran last year
#519
![Ripped](https://ls1tech.com/forums/images/smilies3/ripped.gif)
it was ~1700fwhp
#520
i dunno what to say to that. i guess its really amazing what you can do with a single 4', makes me laugh about all the guys running dual 3' on all motor builds. I cant believe you even tried it much less made that much power and boost. now with bigger motor, turbo, and exhaust.........oh boy.
