Fireball Outlaw Drag Radial Rebuild Thread
#1441
Race your car!
I hear about people breaking those things way too often. Is it the material they use, deaign, or just so much spring pressure that something eventually has to give?
any chance that the rocker could have been weakened from the events that happened on the previous build? I wonder if when the rod broke, if the piston hit the valve and stressed one of the rockers... ?
#1443
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
![Bomb](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_bomb.gif)
#1446
getting upgraded rockers. bigger beam on the intakes (.250 vs .187) and solid body rockers on the exhausts since its a turbo car ![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
jesel says 2-3 day turnaround
#1448
What other way is there?![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
Brian when you test your trans brake in your driveway are you doing a 100% throttle launch or just seeing how it holds and how it engages and disengages...?
I have yet to try mine out, one because I don't have any chance hooking my nitto 35 profiles and two because I haven't really read up enough on how to stage with it the best way and to start to familiarize myself with it.
I know they are all different in the ways they engage and work and time it takes for a particular car to build boost, but the staging and technique is all basically the same. Just looking for some tips or hear on how you are doing it if you don't mind sharing...
![The Patriot !!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_patriot.gif)
#1449
I know they are all different in the ways they engage and work and time it takes for a particular car to build boost, but the staging and technique is all basically the same. Just looking for some tips or hear on how you are doing it if you don't mind sharing...![The Patriot !!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_patriot.gif)
#1455
rockers supposed to ship back to me today...I'm pretty close to Jesel so I should have by monday.
Changed the trans fluid from regular Hygard to Hygard "Light" (aka low viscosity) in an attempt to increase the stall speed of the converter a touch.
Hope to get some more track testing on wednesday....next event is next saturday...
#1456
UNDER PRESSURE MOD
I live in a typical suburban neighborhood with no gearheads at all in my area, and when I recently got done installing the procharger, I left my front bumper off and took a spin around the block just to make sure everything was ok before buttoning everything up. Needless to say the looks I got were quite amusing. When I pulled back into the garage, my wife came out of the back yard and asked what was wrong with my car since she head it whistling the entire time I went around the block. I told her it was the new intake I just put on, and will get quieter when the bumper goes back on.
I wish I had some car-guy neighbors, but it's just mercs, bm'ers, volvos, caddys and soccer mom minivans here. Damn yuppies.
#1459
Race your car!
#1460
When I moved recently I opened the garage door and started my Formula up just to circulate fluids and maybe jar some interest in the project. I let it idle for 2-3 minutes and turned around to see 3 father-son sets standing in my driveway wanting to know what in the hell my car was. Good times.
I'm in for some more results on the new Combo man!
