Fireball Outlaw Drag Radial Rebuild Thread
#1481
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
soso day...
first qual....got reasonable boost on the launch which resulted in a 1.40 60'. went 5.30 @ 145 @ 25 psi
2nd qual....dialued more rpm on the two step, but when I was bumping in the prestage, I went too far and lit both bulbs and ended up with too little boost. Should've just sat on the line
Resulted in a 1.55 60' and a 5.5x @ 148.... @ 28 psi.
1st round. the little screws that hold the scavenge pump to the bracket either broke or backed out (POS design) and the pump fell to the ground in the burnout box. Got shut off
I had added about 5 more psi of boost for that pass....should've hauled a$$ ![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
Oh well....got some changes to make the next few days and will do some testing later this week
![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
![Sad](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_sad.gif)
![Secret2](https://ls1tech.com/forums/images/smilies/LS1Tech/secret.gif)
#1490
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
Good for you Brian, most of us can only imagine the amount of work its taken to get it here so I can honestly say Im happy for ya, its well deserved success. giving Rocket Science a whole new meaning haha
whens the next outing? and do please take a video camera next time too....
#1493
not the best video...the smoke was remnants of the oil in the downpipes...it appears my new catch tank is working...the housings are still oil free ![Hail](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_hail.gif)
http://home.comcast.net/~tfranklin5580/8-6-11_5p30.wmv
#1495
#1498
I see, I purchased a vaccum pump and its helped but Im still having issues with it. You have any pics that you wouldn't mind sharing? If not I understand your a busy man. Btw glad to see your finally getting some progress with the car, thing looks awesome and its going to freakin fly like youve said.
#1499
-10 drain from turbo into a ~2qt tank I fabbed up. Run a -6 line from the top of the tank to my vacuum pump "puke" tank for venting. -10 line from bottom of tank to Turbowerx EXA pump. Run -10 from the pump to the side of my oil pan (above oil level). Hard to see, but pump is mounted just right of the turbo (behind the pull point in the center)
![](https://ls1tech.com/forums/attachments/eastern-members/305936d1310776181-lets-try-again-oil_catch_can.jpg)
