Fireball Outlaw Drag Radial Rebuild Thread
Old 09-03-2011, 07:52 PM
  #1561
Shawn @ VA Speed's Avatar
Originally Posted by Fbodyjunkie06
any updates? 4's yet?
blew out the throttle body gasket last pass-wouldn't make boost.
last qualifier coming up.
Shawn @ VA Speed is offline
Old 09-03-2011, 08:08 PM
  #1562
3.8redbird's Avatar
Camera on the live feed only let me see the back stretch when he seemed to already be on the brakes
looked damn good doing it tho
3.8redbird is offline
Old 09-03-2011, 09:14 PM
  #1563
Fbodyjunkie06's Avatar
turn it up brian!
Another 5 flat
Fbodyjunkie06 is offline
Old 09-03-2011, 09:31 PM
  #1564
  #1565
Nitroused383's Avatar
Looks to be coming on up top!
Nitroused383 is offline
Old 09-03-2011, 09:53 PM
  #1566
Frans96SS's Avatar
5.07 153
It has WAYYYY more in it... It was by far from the best pass... Congrats on a personal best and getting the bugs worked out... Hopefully tomorrow he can play with it alittle more and get it to go alittle faster
Frans96SS is offline
Old 09-03-2011, 10:47 PM
  #1567
Great work brian I know this has got to make you feel better about going to lsfest now if you are still going that is.
Old 09-03-2011, 11:01 PM
  #1568
Fireball's Avatar
blowing thru converter on top. bandaiding my old converter setup which is a 10". Really need a 10.5" converter
22% slip thru the traps
should go close to 165mph if the converter was tighter
not enough converter to get thru 1/4 traps...BG not happening
Fireball is offline
Old 09-03-2011, 11:05 PM
  #1569
Well that sucks to hear. Nothing you can do to fix that, don't think they make a bandaid for 22% slip. What is the stall speed? Just not enough converter to hold the new power?
Old 09-04-2011, 06:24 AM
  #1570
Fireball's Avatar
when I said bandaid, they tried alot to tighten up a small converter
its pretty tight down low. about 3100, but its flashing 7000+ at 35psi
Fireball is offline
Old 09-04-2011, 08:43 AM
  #1571
TracyRR's Avatar
Oh ****! Congrats on your new power!
TracyRR is offline
Old 09-04-2011, 10:33 AM
  #1572
NA$TY-TA's Avatar
Getting there Brian.
NA$TY-TA is offline
Old 09-04-2011, 11:27 AM
  #1573
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,143 Likes on 743 Posts
Regardless of BG, congrats on 5.0@153 dang!!!
Pro Stock John is offline
Old 09-04-2011, 01:37 PM
  #1574
Holy **** 7000+ that's a helluva a flash.
As PSJ said 5.0@153 is HAULING! That's a easy 7.5 pass
Old 09-04-2011, 05:07 PM
  #1575
5.01 154. done for the weekend
once we get the right converter in that car-look out. It's going to be fast!
Old 09-04-2011, 06:48 PM
  #1576
1fast bird's Avatar
I'm hoping that converter will be good enough for my measly next build
1fast bird is offline
Old 09-04-2011, 07:45 PM
  #1577
it's a great converter-just not for 2000+ hp
Old 09-04-2011, 08:06 PM
  #1578
1fast bird's Avatar
Should work for my 1500+hp then I guess
Old 09-04-2011, 08:08 PM
  #1579
MUSTANGBRKR02's Avatar
How are you guys calculating the slip?
Congrats on the 5.0
MUSTANGBRKR02 is offline
Old 09-04-2011, 08:18 PM
  #1580
Congrats on the 5.0
difference between driveshaft rpm and engine rpm
Quick Reply: Fireball Outlaw Drag Radial Rebuild Thread
