Fireball Outlaw Drag Radial Rebuild Thread
#1642
Brian, I'm getting ready to do up my fuel system and I'm looking at your post 1012 on pg 51 and it looks like you have the feed to the filter to a Y which goes to the back of the rails then goes to the regulator from the rails then the return goes to the tank.
Is that the preferred way? I have to get some an fittings either way, I just want to get everything at once and do it right.
On the last setup I had one feed to the passenger front, crossed over in the rear and the regulator was mounted on the rail, then went to the return.
#1645
-12 from tank to -12 100um filter. -12 from filter to pump. -10 from pump to 10um filter. on other side of filter, split into 2 -8 that run to each rail. -8 from each rail to the regulator. -10 from regulator to tank.
#1646
on high hp, running the rails in parallel is a must due to fuel volume.
#1659
patience grasshopper
lets just say I plan on going to the track wed night...
I might have my advanced ET license forms with me too...hint, hint
