ATI Cog set up is here!
I don't see him on this board ever......
Frcefed, I got everything apart, I can't remember exactly what size all of it was, but when I do decide to go looking for my parts I will let you know asap......
back to your question, this might sound stupid , but my allignment was so whacked off, that i finally spaced out the crank pulley with a ring gear spacer out of a old corvette 10 bolt, i then used two 3/8 washers per stand off. my issue was that the crank pulley was too far in ( closer to the block) than the blower, which means if i wanted to allign it i had to push the blower farther into the alternator.
but form seeing your pictures, it seems all you need is two washers per standoff, you still have some area exposed on the blower cog for the belt to ride on when you move stuff.
looking at your pics again, you can also machine down the spacer asp made for the blower cog to bring the cog closer to the case just enough to clear it.
No doubt on a CNC machine or mill. I just hope that my set up isn't that far out of whack too. Who knows. Doesn't look like ASP put a whole lot of research into their 8 rib and cog set ups.I told Lee that we could go thinner on the spacer, as well as some other options, but he never got back to me yesterday... I guess its my problem now. But with you guys it will all be figured out soon.
Thanks Bos, Don't worry about it, I am going to go buy a few different washers of assorted thickness to see what works best. Good little project for today
Heath, Thanks for that email addy
Yeah I got banned for posting up a S/C kit that my brother was selling. I didn't know I broke a rule and now I get redirected when I try to log on
That's o.k. I didn't really go there much anyway.I will ask him if he has any pics I can check out.
Thanks All
I went and bought some 3/16 spacers from Napa and put two per stand off(thanks for giving me the heads up dirty, bos and heath
) Bolted it all up and damn if everything lined up nice and neat. In the pics below you can see the clearance.
alternator to s/c cog clearance. I think I can even run the ATI spacer under the cog spacer and still have room and have more belt contact area on the cog.
You can see without the ATI spacer under the cog spacer that the belt comes right up to the edge of the cog.
Now back to the problems
The belt is too long
Look at the tensioner its all the way down
Ahh Nice a sagging cog belt, I have about 2inches of travel up or down with the tensioner cranked to the max.
Oh yeah, I thought I would give a visual on the s/c headunit to bracket bolts and how long they should be with the new spacers ASP provides.
Does anyone know where I can get these cog belts?? I have a 10408MGT30
Thanks,
J
They all went in with no binding or problems. I was under the car looking at everything and it sure looks awesome, I just hope it works well. From what I see I won't have to cut the tranny lines, looks like it will clear by a few millimeters
I guess I will have to wait until monday to see what Lee says about the belt. For now I will leave it all mounted up.Its beer thirty now, guess I will go have a coke.
J
Kyle
as for the tranny lines, cant you bend them into submission with a tube bender?
Dirty-Tube bender is next on the get list while at NAPA.
I can't believe I don't have one of those yet.J
I have T-Tops
Ahh the memories of the a/c the only time it was used was before all this supercharging madness began way back in 99. With my Powerdyne kit, the car would heat up real quick so I never used it. With the ATI kit and the dual FAL fans upfront the car would do O.K. but then I ditched the a/c, condensor and all and now the car never gets hot
I pay for it tho
J
What do you think?
J
With the tensioner pulley being bigger I can see it taking up more slack in the belt. I wonder why they chose to go with a smaller one and not shorten up the cog belt. Damn I hate waiting for answers. I just want to drive my car again. This project is starting to wear on me. I shoulda just went with the original plan of low boost(9psi)with a decent hit of N2O with the new engine. Oh well we will see how this pans out.
J
