View Poll Results: TURBOED Vs. PROCHARGED
turbo
![](https://ls1tech.com/forums/images/polls/bar2-l.gif)
![](https://ls1tech.com/forums/images/polls/bar2.gif)
![](https://ls1tech.com/forums/images/polls/bar2-r.gif)
![](https://ls1tech.com/forums/clear.gif)
43
50.00%
procharger
![](https://ls1tech.com/forums/images/polls/bar3-l.gif)
![](https://ls1tech.com/forums/images/polls/bar3.gif)
![](https://ls1tech.com/forums/images/polls/bar3-r.gif)
43
50.00%
Voters: 86. You may not vote on this poll
turbo vs. procharger
#43
#44
X3 FOR CHUCK....
I'd like to add some meat to your discussion
You can adj the boost with a **** on a turbo, gotta remove the blower & change pulleys & belts on a S/C
A S/C runs MUCH cooler
A turbo makes more torque
All things being equal they make around the same HP
A turbo has lag
A SC breaks belts
If you have a 6 sp I would go with a turbo for the belt breaking issue alone. Every s/c car I see with a manual tranny goes thru belts like Lindsay Lohan goes thru mascara.
If you show the car (or ever want to) I would go with a S/C because it's easier to make them pretty & keep them that way. Same answer for long distance road racing. Did I mention turbos make a LOT of heat?
All my S/Cs have been self contained so I can speak to how much of an oil leak problem the turbos are. But my oil cooler leaks ALL the time. It's a synthetic oil problem.
Either way if mileage is a concern, try NOS. But it breaks / blows **** up more often!!!
As for which one is faster, I hear a lot of people on hear say turbos. I think they are about the same. You get better 60's with a bloewr & more MPH with a turbo. Although the fastest cars in the world run blowers....
A turbo has lag
A SC breaks belts
#45
Something to REALLY consider depending on where you live, prochargers are 50 state legal, turbos are rarely legal for on road in any way. I live in Ca and this just pushed me over the edge
http://www.youtube.com/watch?v=LdQXW...eature=channel
#47
http://www.youtube.com/watch?v=dCjy7RW1xb0
FFWD to 1:15...
quite honestly i think the difference is clear! S/C'ers for low end, turbos for top end respectively. With the correct setup you can make either do one or the other well, but "its easier to get a dog to bark than to teach a cat to"
the vid above is my 6.0 w/ twin .57mm on only 6lbs making roughly 525whp.
FFWD to 1:15...
#48
LS1Tech Sponsor
ProCharger Power Takes to Road Courses
Posted on July 9th, 2010 by ProCharger
ProCharger superchargers have long been recognized for the industry-leading power and reliability they provide on both street cars and cars set up for drag racing. Today, more and more ProCharger intercooled supercharger systems are finding their way onto cars built for all-out, high-performance driving on winding road courses and race tracks around North America.
When compared with street driving and drag racing, the demands being placed on a supercharger system operated on a road course are significantly higher. Whereas a street or drag car may only see a few seconds of full-throttle acceleration, a road course car goes through multiple full-throttle applications during a single lap.
With most lapping sessions lasting 20 to 30 minutes, road course drivers spend at least 3/4 of their driving time on the throttle. To put this in perspective, a street car making 12-second 1/4 mile passes would have to make approximately 75 passes to equal the amount of time spent on throttle (and in boost) that a road course driver experiences in just one 20-minute lapping session! That is a LOT of time spent in boost…and that was just one session. A driver at a typical road course lapping day can log as much as two hours of on-track driving time.
C5 ZO6 Corvette
![](http://www.procharger.com/Blog/Snitzer_ZO6_ontrack.jpg )
As if a stock ZO6 Corvette wasn’t already the ultimate track car, Tom Snitzer enlisted long-time ProCharger dealer Bob Beam to build an even more wicked track animal. Snitzer’s C5 ZO6 now takes to the track with a built 402-cid LS2 equipped with an intercooled ProCharger F-1C supercharger set up.
![](http://www.procharger.com/Blog/Snitzer_402_F-1C.jpg)
On the dyno, this car has laid down 804 rwhp and 728 ft.-lbs. of torque. On the track, it simply lays down rear tire tracks from the exit of every turn.
C5 ZO6 Corvette
http://www.procharger.com/supercharger/blog/
Back at Exotic Performance Plus, when we had the D-1SC on the above Corvette at 16 psi and 740 rwhp, the car got 28 mpg on a vacation, the customer took from Chicago to the East Coast and back. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
![](https://ls1tech.com/forums/signaturepics/sigpic168855_1.gif)
#49
Someone else mentioned the idle noise. For me this was a major factor in going turbo instead of supercharger. If you pull into a parking lot people will know you have a supercharger because of the whine. If you drive your car alot and go places with your girlfriend the car is going to be seen and heard by others. I like using mine, not just taking it out for a spin and then straight back to lock it up.
![Devil](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_devil.gif)
#52
My opinion,
Properly built turbo setup will out do any centrifugal s/c setup anyday.The only benefit to a s/c is ease of installation.
a s/c uses power from the crankshaft to turn it-to make 1000bhp the engine is actually making much more-so your actually beating up the engine more.
a turbo uses heat energy to make power-the heat energy is lost in other types of engines-basically it's free horsepower
with proper sized turbos,a properly built engine,and proper piping-there is no boost lag-if there is,something isn't right
a turbo will always make more hp than a s/c-especially top end power.
you don't need countless pullies to change boost-in fact with a turbo and the proper boost controller,you can control your boost at any rpm-not just stuck with something you're not happy with.
oem's use turbo's for a reason-there durable and way more effiecient than a centri s/c.
i'm sure i can go on.
#56
My opinion,
what hes said!!!
footnotes: Turbos own !
![Cheers!!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cheers.gif)
#59
technically, turbos aren't really free horsepower; exhaust doesn't like restrictions. and that turbine? yeah. that's not exactly a wide open passage for exhaust to breeze through. is it going to suck up horsepower like a blower attached to the crank? probably not, but it isn't "free" either. just sayin.
![1poke](https://ls1tech.com/forums/images/smilies2/1poke.gif)
#60
i remember i had a race with a s/c t/a 2 yrs ago, against my all motor camaro (had cam only, with bolt-ons at the time). it was an even pull from 60 to 130. that didn't impress me at all, but my car was a beast on the top end for what it was then. now, i've ran against motorbikes, from about 60 to 140 and pull them about a bikelength. i need to run against a s/c car to see what it can do.
