Force induction + nitrous
Old Aug 16, 2010 | 07:28 AM
LTXBOI's Avatar
Default Force induction + nitrous
F.I car + nitrous pro's and con's..also heard IF I RAN 100 SHOT WITH A F.I CAR WOULD IT DOUBLE THE 100 SHOT OR TRIPLE IT?
Old Aug 16, 2010 | 12:20 PM
Ryans99ls1's Avatar
when you use nitrous with FI, the power increase is more exponential as you add more boost/nitrous, not so much 2 or 3 times the original shot.
Old Aug 16, 2010 | 01:51 PM
fatmat80's Avatar
there is a guy on here with a white ss with black hockey stripe than has or had a 347 with a vortech and a 150 shot.. i cant remember his name but i think he put down like 900rwhp? my question to you is why would you need it ?
Old Aug 16, 2010 | 03:27 PM
pwrtrip75's Avatar
I ran a 50 shot on my 5.3 w/ boost, it spooled a little slow with out... w/o ran 10.55 @ 128, with the 50 shot ran 10.31 @ 131 I had a really shitty converter also... but it worked ok never had any problems.
Old Aug 16, 2010 | 04:29 PM
LTXBOI's Avatar
lower IAT, FOR HEAVY STREET/STRIP ACTIVITIES WANT TO RUN A SPRAY BAR ON INTERCOOLER AND A LINE TO MOTOR!!! MY P1SC+ NITROUS WILL HELP REACH MY GOALS AND MORE
Old Aug 16, 2010 | 05:19 PM
dschmittie1's Avatar
I would run Meth before I sprayed N2O on my FI motor
Old Aug 16, 2010 | 05:39 PM
TurboAv's Avatar
I'm going to use nitrous to spool a big turbo in a rearmount configuration. They make controllers that will ramp the nitrous off as the boost comes up.
Old Aug 16, 2010 | 06:10 PM
ibex37's Avatar
well its a different set up completely but i run a "75" shot on my neon and it made over 90 horse power to the wheels, so i would say there is a bit of truth making more horse power then advertised
Old Aug 16, 2010 | 06:18 PM
LTXBOI's Avatar
but why dont they provide the same effect some what.just want to make sure when pushing the car hard in hot weather that it's stay very cool the meth works but only when for intake not the intercooler!
Old Aug 16, 2010 | 06:35 PM
IT_SS's Avatar
if i'm not mistaken, No2 acts as an oxidizer and meth act as a coolant/fuel.
Old Aug 16, 2010 | 06:48 PM
TurboAv's Avatar
Correct. You need to add fuel to nitrous for the power increase. Meth is it's own fuel.
Old Aug 16, 2010 | 07:57 PM
LTXBOI's Avatar
ooohhhhhh i see
Old Aug 16, 2010 | 08:03 PM
LTXBOI's Avatar
cool thanks
Old Aug 17, 2010 | 06:58 AM
chuntington101's Avatar
i think you need to do a little more research before you decide if you dont understnad how meth and N2O work!!!!!..........
use the serach button, its you friend!
Chris.
Old Aug 17, 2010 | 07:05 AM
Yes you are correct to a degree. with N2O you are basically adding addtional oxygen to the intake charge. with added fuel you will make more power. However with a FI setup the N2O helps cool the intake as well. this is where you see the added power come from. So if you are spraying a 50shot and making an additional 90bph then you would be getting about 40bhp just from cooling of the intake air!!!.........
Meht is just another fuel. as you are adding it mailes away form the intake it has loads of time to evaporate and thus helps cool the intake. this is why carb guys often dont bother with intakercoolers. thye are using fuel to help cool the intake charge. Alky also adds a little octane to the mixture, never a bad thing!
Speaking of octane, what very cheap, readily avalaible, perfectly safe liquid has over 10,000,000,000,000 octane?
Chris.
Old Aug 17, 2010 | 08:04 AM
98Z28CobraKiller's Avatar
Restricted User
Nitrous will increase cylinder pressure thereby causing you to have to reduce timing or risk detonation. The additional power is mostly due to the additional cylinder pressure already present from FI and the cooling effect it has on that charge.
Meth is a fuel and has higher octane than pump gas. So it cools the charge AND raises the octane which allows for MORE timing. Some people run straight meth and others mix it with water which further ups the octane but reduces the cooling effect slightly. I'm not a big fan of spraying water into my motor though.
Old Aug 17, 2010 | 08:16 AM
blown94's Avatar
Im pretty sure you've got that backwards. The methanol is what adds the octane. They say water helps cool the charge better, and the methanol is simply a fuel which has a cooling affect as well.
Read post #10 on this page:
http://www.snowperformance.net/faqs_...?type=gasoline
Old Aug 17, 2010 | 09:49 AM
ibex37's Avatar
Chris.
answer in the form of a question
what is water?
Old Aug 17, 2010 | 03:57 PM
Restricted User
I was under the impression that the methanol had better cooling properties because of how quickly it evaporates compared to water. If this is the case, then the only reason to not use straight water is because the meth lets you stretch your fuel system out a bit. I'm going to have to look into this a little further.
Old Aug 17, 2010 | 05:22 PM
OUTLAWZ RACING's Avatar
Huh? How does the meth water mix reduce cooling the intake charge? It was my understanding the water will help pull the heat out the intake aswell as the meth, And those of whom run straight meth need the octaine. Im not being a dick, but is my understanding wrong or off?
I sprayed a 50/ 50 mix on my car during hiway runs and never seen iat past 80*.
