how amazing will this cam be for a twin turbo 5.3?
Goal is peak power around 6800rpms, shift point is 7200 rpms.
Cam is a 232.3/233.8, .612/.598 111+2
323 cid with stock 862 heads and performance valvesprings
Stock compression of 9.4. E85 fuel,water methanol inection, non intercooled.
Twin t70 turbos .68ar
Car weight is 2900lbs
So, I'm curious what you all think this engine will make NA, and how that cam will work under boost
Somehow, I doubt that backpressure will be an issue : )
the torque converter is built to stall at 3500rpms but the guys are not too far away from me and dont charge a lot to restall.
Im using 4.86 gears on a 31" tire so it should rev pretty quickly
