Oil pan fitting for return line
Old Oct 16, 2010 | 07:34 PM
Sweet_SS's Avatar
Default Oil pan fitting for return line
Is it safe to say most of you had to take out your oil pan for this? I need to have a fitting welded for the return line and I don't want to hassle with the K-member, but I will if I have too. Do I have any other options?
Old Oct 16, 2010 | 09:57 PM
1_bad94Camaro's Avatar
I did mine while i had the motor out. I'd say pull the pan to be on the safe side.
Old Oct 16, 2010 | 10:53 PM
Gonoma's Avatar
yea from what i hear oil is flammable lol
Old Oct 17, 2010 | 12:47 AM
Adam86's Avatar
No way you'll want to tap the pan and risk leaving the shavings in there.
Old Oct 17, 2010 | 07:21 AM
JAX04's Avatar
Im going to agree, people will tell you that you "can" do it while its still on there, But screw that. Way to easy to drop some shavings and suck them up.
id pull it, im tapping mine today
Old Oct 17, 2010 | 10:34 AM
Sweet_SS's Avatar
Thanks for the replies. I will be pulling the pan.
Old Oct 17, 2010 | 01:20 PM
JaYZeig's Avatar
are there any threats as to having a fitting welded on the timing cover? im bulidin a turbo setup and was thinking of going this way and will do it when i swap my cam out.
Old Oct 17, 2010 | 08:41 PM
flame's Avatar
Would it be possible to use the low oil level sensor hole or is that too low in the pan? Just a thought.
Old Oct 17, 2010 | 10:08 PM
Sweet_SS's Avatar
Where are you guys mounting the chain for the hoist?
Old Oct 18, 2010 | 03:34 PM
FastKat's Avatar
I usually put bolts in the front and rear of the heads, but I'm not gonna lie... I've picked up the engine and trans using straps through the exhaust manifolds, too.
Old Oct 18, 2010 | 04:55 PM
Sweet_SS's Avatar
I might have to try the straps. Thanks for the response.
