Is there a better turbo than a tc 78 that's the same size?
Old 10-20-2010, 11:17 PM
SPRAYED 01's Avatar
Default Is there a better turbo than a tc 78 that's the same size?
I'm running a tc 78 with a 3 inch dp.makes 670 hp and 705 ftlbs through a stalled auto and 9 inch.its pretty much maxed at 16psi on my 348. Is there anything out now that is physically the same size but can make more power.i think I need another 40hp to hit nines.
Old 10-21-2010, 05:44 AM
HydroStream6's Avatar
Precision 78GTS might be your best bet.
Old 10-21-2010, 05:47 AM
Josh@KY-Turbo's Avatar
I have several customers in the High 9's with the TC78 on 346-370ci engines. I wouldnt rule the turbo out just yet.
Old 10-21-2010, 05:49 AM
yelo04goat's Avatar
what kind of times are you running... details on the motor..?? and some on the car if you dont mind... weight??
i got a tc76 and hoping for mid to lower 10s (porky car)
Old 10-21-2010, 07:26 AM
stevegrizzle's Avatar
have you checked how much back pressure you have?
Old 10-21-2010, 08:56 AM
CarsandWomen's Avatar
I was thinking the same thing, seen several other members making more power than that with the TC76 and 370's, hell theres a few running T70's on 370s and doing ok.
Old 10-21-2010, 09:54 AM
cracker's Avatar
Precision Billet Wheel 76 or 78 HPS
I don't even know if the billet wheel 78 is out yet.
Had really good luck with the 76.
Old 10-21-2010, 09:55 AM
mike13's Avatar
I don't know how they do it, my TC76 .96a/r had so much back pressure with just heads and cam. The car would just flatten out about 5k.
Old 10-21-2010, 10:29 AM
black98ws6ta's Avatar
I also think you should be able to go 9's on that turbo, are you just going by dyno numbers? I've had some a couple 680-700 rwhp turbo stalled auto cars trap 145-150. They just dont dyno well sometimes.
PTE 76 is alitte bigger in physical size but will produce quite a bit more hp.
Old 10-21-2010, 11:02 AM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,143 Likes on 743 Posts
Alex' car is pretty heavy, it's full weight plus the turbo kit.
Old 10-21-2010, 03:33 PM
I was refering to full weight car's, get the car hooking good and there is no way it shouldnt go 9's at 670 rwhp on a stalled turbo car.
Old 10-21-2010, 06:47 PM
SPRAYED 01's Avatar
Its your basic forged 348 with 670 ish to the tire.I'm running a tbrake and launching off 9lbs.i went 10.4@133 with a 1.66 60ft.still running stock springs and shocks.I'm going to put a 28 inch tire instead of the 27 I was running with qa1s on it and see what happens.I'm very happy with the turbo but I think another 40hp would make 9s alot easier. Not sure on the back pressure,,3 inch dp with cutout.
Old 10-21-2010, 07:25 PM
Launching on the tbrake with 9lbs and only cutting a 1.66? Something is definitely not right there...
Old 10-21-2010, 09:12 PM
LS1Tech Co-Founder
Alex your car is so heavy you should be able to hook a 9.9 pass on a 26 inch tire.
Next time you run, figure out if you are spinning or not leaving on enough power. Maybe you need a bigger spring in the waste gate?
Old 10-22-2010, 12:42 AM
skinnies's Avatar
686rwhp here at 18lbs on a stock 5.3 with that turbo and the times in my sig. Have you tried turning up the boost, will it just not make anymore?
Old 10-22-2010, 05:17 AM
Johnv's Avatar
What size intercooler are you running ?
Just went from a 24x12x3" to a 4" core and picked up 3 psi at the manifold
(tc 78 on 383)
Old 10-22-2010, 09:15 AM
LS1TECH Sponsor
DrTurbo's Avatar
Nothing will drop in that is the same exact size. The 76 and 78GTS are a good bit larger.
Old 10-22-2010, 02:22 PM
IMPATIENT 1's Avatar
that's impressive! stock 5.3 as in didnt even change cams or jus a stocker with the basic 5.3 upgrades and cam?
Old 10-22-2010, 03:56 PM
LS1Tech Co-Founder
skinnies are you like < 3000 raceweight... Props btw with the rx7.
Old 10-23-2010, 01:40 PM
code4's Avatar
I've gone 9.8 on my my full weight fbod with the tc78. It is completely maxed out as far as back pressure. I tried a 50 shot & got some pretty good blow by out of my valve cover vent.
Mine is a .96 AR. I wonder how much it would help going to a larger AR?
Quick Reply: Is there a better turbo than a tc 78 that's the same size?
