AES 390ci - Now with Callies Dragonslayer crankshaft
Old 01-10-2011, 11:48 AM
  #141
AES Racing's Avatar
Originally Posted by C4 Silver Guy
I got one and couldn't be happier with the engine or the AES guys.
You were 390 build #001
Thanks Russ
Old 01-10-2011, 12:04 PM
  #142
EDISKRAD EHT's Avatar
Sorry if I missed it, but are you willing to sell the rotating assemblies separate?
That 399ci LS3 looks even better.
Old 01-10-2011, 12:11 PM
  #143
Josh@PremierAutosports's Avatar
Originally Posted by JimS
I have Dart 225 heads. I'm thinking I'll go with the TVS2300. Are the heads going to be ok? What boost level am I looking at with the TVS 2300 and your 390?
That would depend on your pulley configuration. But that 390 will be able to handle everything the tvs2300.
Old 01-10-2011, 12:22 PM
  #144
JimS's Avatar
My lack of knowledge is showing again. I hate when that happens
I have a Lasabre parked in my storage garage that I use for road trips only. I've been threatening to trade it for the car in your sig! I want one of them! Problem would be that before long it would be my second hot rod and I'd still need a road car.
Old 01-10-2011, 12:33 PM
  #145
JimS's Avatar
Here's what he posted on 01-04-11
"Rotating assembly
Compstar 3.825 crankshaft
Compstar H beam 6.125" rods
CP Piston set -15cc dish 4.030" pistons x 1.200" CH
CP .180" wall chrom-moly piston pin set
NPR ring set, gas nitrided steel top ring, napier 2nd, std tension oil ring.
King HP rod bearings
King HP main bearings
Crankshaft is balanced
$1995 shipped to lower 48"
Dammed good price... seems to me.
Fast Times got my attention 10 or 15 years ago when they were building 65 Impala's that were in the 8's! And, being from the 50's myself.. when c.i.'s was king(!) it really shocked me to see they were doing it on short stroke engines. If memory serves they were even de-stroking some engines and makeing unreal power doing that. This 390 seems to follow along the lines of that philosophy.
Old 01-10-2011, 03:53 PM
  #146
"Rotating assembly
Thank you sir. I agree that it's a pretty good price. Almost certain I'll be going with either the LS2 or maybe the LS3 rotating assembly.
Old 01-16-2011, 08:15 AM
  #147
JimS's Avatar
Originally Posted by AES Racing
In my own combination i'm running 62cc, it ends up around 10:1 compression
Given this I guess my Dart 225's should work well with the 390 and a D1? What boost level could be attained?
Old 01-16-2011, 09:14 AM
  #148
LSX-coupe's Avatar
If you supply the block, can take $350 off the price
(Take $3495 - $350 = $3145, in that case need a block shipped to me to build. )
Outright price for Aluminum block version
385ci Aluminum LS2 block $3995
399ci Aluminum LS3 block $4350
Either Version
CP pistons 2618 forged -15cc R/Dome dish
Gas nitrided ring steel top ring (made by NPR Japan)
Compstar H beam rods ARP 2000 bolts
Compstar 3.825" crankshaft 24 or 58x reluctor
King HP bearings
ARP main studs
LS2 or LS3 block
Is that compstar or c crank?
Old 01-16-2011, 05:48 PM
  #149
Restricted User
98Z28CobraKiller's Avatar
Rotating assembly
back to work for me now.
That's my next go round right there. If I gave you the weight of my rods, could you do it balanced minus rods. Only because I think my rods are a little tougher then those. If so, how much?
Old 01-16-2011, 10:13 PM
  #150
AES Racing's Avatar
yes compstar C-series crankshaft
Old 01-16-2011, 10:14 PM
  #151
AES Racing's Avatar
We can do that, take $550 off the price
Old 01-16-2011, 10:15 PM
  #152
AES Racing's Avatar
I'm planning to run Dart heads on my own 390.
Old 01-20-2011, 07:27 PM
  #153
JimS's Avatar
Bump for a good thread and what sounds like a great foundation for a bad-*** engine.
Old 01-21-2011, 01:00 PM
  #154
wilson34's Avatar
With the compstar rotating assembly you listed at 1995 shipped, could you do a 4.070 piston for an LS3?
Old 01-21-2011, 04:41 PM
  #155
LSX-coupe's Avatar
Hey Fraser how do you feel about using the c crank to spin a tvs2300 or Whipple to the moon. Sarcastic. I would spin it to Max potential.
Old 01-21-2011, 07:35 PM
  #156
AES Racing's Avatar
I'd rather use a dragonslayer crankshaft for that application, can order it with double keyway snout.
Old 01-21-2011, 07:36 PM
  #157
AES Racing's Avatar
not available yet, if I get an update on that i'll PM you
Fraser
Old 01-22-2011, 04:32 PM
  #158
99bluefirebird's Avatar
Also interested in the 4.070 LS3 based engine
Looks like 398 c.i. (6.5L) with 4.070x3.825
Will the pricing be similar to the $3999 LS2 based 390 if compstar internals are used?
When do you recommend coating the pistons or main/cam bearings?
And would you recommend any options for the LS3 block to hold at a maxed out D1Sc (800hp?)
Old 01-28-2011, 11:52 PM
  #159
AES Racing's Avatar
Been PM'ing 99bluefirebird and couple others, 4.070" pistons are in the works.
Coat bearings anytime, stock to race build, everything in between.
Not required but does help.
We can pin the mains, option, $300, or we offer it with pin mains and coat pistons dome/skirt for $500.
Old 01-29-2011, 08:15 AM
  #160
SirNemesis's Avatar
Finally got mine together. Will be going into the car next week
Quick Reply: AES 390ci - Now with Callies Dragonslayer crankshaft
