Best intake for Forced Induction
Old Jan 5, 2011 | 08:36 PM
  #101
020NN20's Avatar
Looks like a proflo with a shortened plenum(long wise) Looks like the back cylinders would benefit even more with positive pressure coming in and straight down the rears.....IMO
Old Jan 5, 2011 | 10:02 PM
  #102
lunati397's Avatar
Originally Posted by Shawn @ VA Speed
here is a couple spy pics of an LS intake coming to market. Will be available early summer.
This is one half. will be 2 piece design for easier porting and other internal mods.
whos making this and do they need testers
Old Jan 5, 2011 | 11:03 PM
  #103
98Z28CobraKiller's Avatar
Restricted User
Originally Posted by Clean94Z
He was a full sponsored racer who had been doing it for a long long long time. Said it was time to get out of the game. Its a full time job racing every weekend on top of his full time normal job and his family. Said it was time to focus on other things. He parted the whole car out.
He is most certainly right it is a High Hp intake and it is very tall. The intake is 8 inches without the hat and 14 inches with. The longer runners and equal runner length is why its suppose to not effect the low end like the typical single plane carb style intake. But it also does not come with the typical carb intake price. I bought mine used with hat and rails for $1600.00
Here is a graph of it on a built ls7 na setup. {ENGINE DYNO}
Is this a 427 or a 451?
Old Jan 5, 2011 | 11:06 PM
  #104
Restricted User
Shawn, looks like that guy would fit under an fbody cowl.
Looks good.
Old Jan 5, 2011 | 11:56 PM
  #105
c5blkvette's Avatar
Looks like a nice intake
Old Jan 6, 2011 | 07:48 AM
  #106
Shawn @ VA Speed's Avatar
I'm not a liberty to say who is making it.
We are machining the castings and doing the distribution for them.
We are also doing the testing
  #107
Looks good.
yes,it will fit under and Fbody cowl
Old Jan 6, 2011 | 08:02 AM
  #108
JAX04's Avatar
looks like a helluva nice intake, can only imagine the price on this though
Old Jan 6, 2011 | 08:32 AM
  #109
Fireball's Avatar
what about cathedral
Old Jan 6, 2011 | 08:33 AM
  #110
Need_a_Camaro's Avatar
When can we expect to see some numbers? Testing, and pricing? I just picked up a Vic Jr setup, but am always lookingfor something better.
Old Jan 6, 2011 | 11:26 AM
  #111
Clean94Z's Avatar
built ls7 based 451
Old Jan 6, 2011 | 11:55 AM
  #112
Restricted User
built ls7 based 451
That's ALOT of cubes for the average FI guy. Is that an "out-of-the-box" intake or the one that you pictured?
Old Jan 6, 2011 | 12:18 PM
  #113
Restricted User
Well, in that graph the Wilson sheet metal seems poor compared to the others. With boost do you think it'll be the same ?
n/a if you fitted a carb intake with a tight elbow to clear your cowling....I'd think it would be pretty crap.
With boost ? I'd say it will still produce excellent results.
I see what you are saying about some areas, and I guess it's hard to argue with that. But intakes need to be tested in the manner they will be used.
Before there is boost, there is NA. What I mean is that you have to make NA power to get the turbine spinning to make boost. When you are dealing with a drag race situation, you have to be able to build boost on the line or you will never ET well.
Add the magic of a torque converter and it starts to get complicated because the converter stalls different at different power levels. That means that when you get on your tbrake with no boost, the converter has to be loose enough to get up to where you build boost but yet tight enough to where it wont blow thru up top under boost. So the intake/head combo need to be able to make enough torque to get you up on the tbrake/2step to where it will build the boost that you need fast enough to launch when the tree drops. There are ways around this but you start adding layers of complication. Nitrous can be used to get you over the hump and there are mods like variable stall control which regulate the pressure at launch making a tight converter feel loose on the tbrake. That kind of stuff should really only be used to run monster turbos on smallish cubes and not so much to compensate for a poorly pieced together combo.
Old Jan 6, 2011 | 01:29 PM
  #114
JAX04's Avatar
Gonna say this now, this thread is getting very interesting to say the least.
carry on...
Old Jan 6, 2011 | 06:00 PM
  #115
Texas_WS6's Avatar
Shawn! You are killing me! If you have an idea what that intake might cost, PLEASE PLEASE PLEASE PM me so I can start sacking the money back for it. If it will fit under an f body hood, and it is worth the money, I want to be the first in line to buy buy it.
Just killin me!
Old Jan 6, 2011 | 06:23 PM
  #116
6techniques's Avatar
jeez I want to know more about that intake!
Old Jan 6, 2011 | 07:16 PM
  #117
Clean94Z's Avatar
Its a Mast Motorsports Precision Inductions LS7 intake. Its a out of the box from them
http://www.mastmotorsports.com/2010/...nifolds&id=380
Old Jan 7, 2011 | 06:39 PM
  #118
john marcella's Avatar
Never!
Old Jan 7, 2011 | 07:23 PM
  #119
FirebirdSS's Avatar
http://i256.photobucket.com/albums/h...eprototype.jpg
http://i256.photobucket.com/albums/h...rototype-2.jpg
If this would have any chance on fitting under a stock ss hood. I would love to own one for my tt setup.
Old Jan 7, 2011 | 07:25 PM
  #120
mike13's Avatar
I heard the Weiand Street Warrior is coming out just thought it would be funny to bring that up. I'm still staring out the window waiting for the UPS guy to drop off mine.
