1142 rwhp 1147 rwtq budget 347 w/ GT-88
#41
Effin' sick dude, congrats! What are you doing for fastening on the heads? Just ARP studs, no pushing water at that boost? I would really look into some adjustable rockers, AFR's are notorious for screwing up valve guides with stock rockers. I had 4 in each head that had to be replaced, buddy had more, and another local car is starting to burn oil too. Sick setup, I'd like to check it out personally at TX2K11 if that's cool.
#43
#47
Eh the 160's are a little rich on Decel and idle but it doesn't mess with the way the car runs. It was either $800 bucks for a set of injectors and a box or almost $1300 for high impedance injectors..
#51
Would you have preferred high impedance over low? Personally, low > high IMO so I'd say you're good. I think the only high impedance injectors I'd try would be ID1000's or ID2000's. Local E85 guys love them. What's your duty cycle on the 160's?
#53
so how much timing did you have into it and peak power if you dont mined me asking
#58
As far as doing triple pumps in a plastic tank, its a PITA, I forgot to snag pictures of it.
