Procharger f1-a with stock crank?
Anybody running this?
I know the stock crank has been proven strong but how does it hold up to the extra tension from the blower? What power level are you at? What tensioner setup are you using?
8 sec potential, 12 sec slip
Im running the stock crank with my F1 (just an F1, not an F1A) with no problems from it. My MAF tune I made about 700rwhp, but I'm hoping for more than that when my SD tune gets done. Which should be within the next couple weeks. GSS has it now and is working on that. I am running the stock procharger tensioner with an extra idler pulley.
With my last motor my F2 broke the crank pin -that was an eagle 4" crank. This time I went with a lunati pro series with double keyway. That should hold it. At lower power levels you should be ok with a stocker but it's much easier to put a good crank in while you have the motor apart vs paying to have it pulled, rebuilt, new crank, etc...
How many miles do you have on this setup and what do you limit your rpm to? I think keeping the rpms at a reasonable level will help hold it together as well
I was thinking the same thing about a quality tensioner. Those are very nice numbers out of a D1
I dont want to spend a ton on my first shortblock in case I mess it up. I plan on running a 5.3 or 6.0 with just some forged rods and pistons until I man up to something like a 402 or 408 I dont plan on maxing this blower out with this first setup, i'm going to be limited by fuel anyways until I can afford more than a dual 255 setup with stock rails
The F1 or F1a is what I'm looking at for my next engine but not on the 5.3 platform. I'll start with the LQ9 6.0 block and then add c.i. to that. Maybe 390, or 402 or 408 or maybe 427. I think I can reach my goal of 1000 hp using one of the F series Prochargers with a LQ9 foundation.
