Turbo Tq curve??
Turbo Tq curve??
Doing a 5.3 Turbo build up in a mid-engine GTM. The transaxle has a Tq rating that I Dont need to exceed (450rwtq) but would like as much HP as possible. Anyway to decrease TQ and add HP on a Turbo build?
Many 5.3 turbo builds around 6psi show something like 390RWHP/450RWTQ, would like that flipped if possible.
Talked to Jose at Forcedinductions.com he mentioned going with a larger turbo would lower Tq and raise HP.
Anyone have any recommendations? I have some room to work with.
Don't need to exceed 450RWTQ but hp can be a different story.
Horsepower is just a function of torque and RPM. Moving your power farther to the right on your dyno graph will net you less torque in the early RPM range. A larger turbo won't spool as soon which would shift power to the right. Cam selection can shift power to the right also. A boost controller using the boost x RPM ramp method could get the same thing done too.
Thanks for the reply, totally new to turbos. I am wanting to use a stock 5.3 with just ad LS6 intake. With the factory cam I believe they shift at 5700RPM, so probably shifting there?
May need to look into, anymore info?
That wouldnt be a problem. I personally would put a proper turbo on the thing and control it with timing and/or boost. That way if you ever upgraded the drivetrain you wouldnt be stuck with a laggy turbo.
That is correct. If your using the turbo to tune the power curve to some degree that is how it would be done.
