Got the car back. It made 905rwhp 802rwtq on 13lbs
#61
There's always those quick spool valves that they have a thread posted in the forced induction. I'm not sure why your having problems with it spooling. The exhaust housings are .81's aren't they? I would figure that it would be uncontrollable anyways with the power band in it's present place. I would have guessed that it would just spool insanely fast.
#67
I would def. Say to look into a couple of quick spool valves. From what I've seen they really help in spooling faster. I believe it was zombie (I think was his tech name) did some graphs and tests with them and saw a 33.3% faster spool time.
#70
Around an oring? Or into the cylinder? If it's around one of the orings, try twisting it while it's running. Like rock it 180* back and forth. Sometimes the oring doesn't seat good until there is pressure behind it. If that doesn't work, take it out and inspect the orings. Sometimes the rail side is sharp and can cut into them during installation. Put a little vaseline on the orings before you pop them in the rail.
#80
Spool valves go right under the Turbo hotside inlet( in your case t4 flange) it just has a butterfly valve on one side that opens at a desired point in time, you can use
a boost switch or rpm switch to operate them. With one flap closed the exhaust gas velocity increases spooling the Turbo quicker, it then opens to prevent choking. Think of pinching a garden hose with your thumb. Here's a link
http://m.youtube.com/#/watch?desktop...LKVgg8po&gl=US
