2 1/4" turbo crossover
I believe one of the sponsors (dont remember who) posted that some ppl make over 1000hp with 2 1/2" crossovers so I'm wondering if 600-650rwhp can be made using 2 1/4" tubing.
8's on 2 1/4" tubing is crazy!
I figured to help combat backpressure that I would just use a bigger DP. I'm thinking of going tc78 on stock cubes with a 3 1/2" Dp. That way the exhaust wont be so choked. Def gonna be using a 44/46mm wg too.
The thing is, I wanna do to the whole turbo k-member thing rite now but time may not permit. I wanted to have the setup running for the summer. I was thinking of routing the passenger side under the stock k-member for now just to have the setup on the car.
I think that 2 1/4" tubing and a notched k-member might have to do if I plan on doing this soon.
The 2 1/4" will prolly make the turbo spool pretty fast.
I seen those threads b4 and tried to find them. I was prolly typin in the thing tho. I"ll look aagain tho.
Goodlook!
thanks for the site i will look through them .
Idk guys, I maybe cheaping out on the turbo k-member and notching the stock one for this setup.
On 2.5" tubes....
164.8mph to the 1/8 mile
4.70 on a 1.25 60'
7.29 to the 1/4 mile on a 4.84 1/8 mile and a 1.29 60'
I think 6's are possible with 2.5" tubes.
Backpressure is caused by your smallest point in the exhaust side which is the turbine by far. From smallest to largest or highest to lowest airspeed.
Turbine housing
Exhaust valve
Crossover
Header tube
4.70 on a 1.25 60'
Turbine housing
Exhaust valve
Crossover
Header tube
Im trying to picture this in my head and this is wut it looks like.
I may try that tc78 with 1.15 exhaust housing with 2" tubing. I cant see 2" being to small.
Think of the turbine housing as a nozzle. You've got a preset amount of air going to it, its going to require a certain amount of time to develop the amount of drive pressure needed to spin the turbo. The larger the section between the turbine and motor, the more time and heat loss that occurs.
