CBR F2 System First Install
We asked them to run the stock motor as a favor to us so that we could get numbers on the stock engine, for testing purposes.
In the mean time Chris and I are ******** and elbows while working on our new kit, codenamed "the lot lizard"
This kit will come 2 different ways. To keep A/C or not keep A/C.
The non-A/C version is going to start at $999 and the A/C version is going to start at $1499.
They will both use the factory K member come with an alternator relocation kit (ours made in house on our CNC) and will consist of truck/C6 manifolds depending on version, CBR hotside, and a few other trinkets required to get the job done.
As always, Chris and I are going to use some real slick innovative packaging, that makes it really simple for you to finish it off very easily.
We are also offering a complete single setup now for $5199 (A2A, turbo, wastegate, BOV, coldside, hotside, truck mani's, all fasteners clamps silicone couplers.)
If anybody wants one just give me a call.
IE no standing up the radiator and no ditching the stock fans?
if so I am hoping its the ticket to migrate from the rear mount to front mount.
I am unwilling to lose AC or the stock cooling system so hoping the answer is yes to both.
The lot lizard's focus is inexpensive quality that gets the job done.
It is a turbo system with compromises just like all the other kits out there.
Thats why we made the F2 kit, it has no compromises, but it is not inexpensive.
I really don't know what to tell you other than if there was a way to do both of those things cheaply it would have been done already.
I have been thinking of using the stealth pump from Aeromotive for a build I'm doing with a buddy of mine. It will end up getting 2 of them in the future.
Also if you need those aeromotive pumps call my bud Josh@Lashway motorsports he has the hook up on those things. I was at Lashway last week and he had a number of them on the shelf and I'm sure that he would take real good care of you.
I think the area behind a spoiler is a low pressure area.
amount of time after you get out of the gas.
The top of the heat exchanger is covered with shroud and a fan mounts to it.
There’s not much room for hot air to passed through the heat exchanger.
If you have a suggestion for a new mounting spot let me know.
are opening the last page.
Owner: Adrian Gonzalez
Car: 2002 Pontiac Trans Am WS6 w/ stock motor
Mods: Dana S60 rear end and Yank converter
We added a Methanol injection kit to the car at Adrians' request so we could push the setup really hard on the stock motor.
Here are the pics:
