bulk head or weld opn bung for oil drain from turbo on aluminum f-body pan?
i have my oil return hole pretty close to the rail of my oil pan and im worried a weld on bung might not be able to be welded all the way around....
is any one using a bulk head fuel cell style fitting for the oil drain on a factory cast aluminum pan?
will this hold tight and not leak?
its a -10an male fitting...
thanks for the input guys, i think id definitely rather have it welded, ill have to ask the guy who would be welding it for me...
heres a pic of where it would be located
Not ghetto at all.... the pan is well thick enough to tap... 1/2 NPT would be fine.
I stuck mine in between the oil pan ribs/gussets whatever you wanna call them...looked like a spot made for it.. I Welded it though because I had the pan off anyways, and I had the weld fitting.
