91mm 2 step timing on e85
Old Jun 18, 2011 | 08:59 AM
gennex's Avatar
Default 91mm 2 step timing on e85
how much timing can you throw at an e85 setup with a 91mm, car is 10:1 compression, 396cu, with 20* it make 6psi, id like to leave on 10-11, will 30* make help alot or even 40*? ive seen guys in the 35* range and wonder if 40 or higher would help. the protree is hard to get the boost up on.
Old Jun 18, 2011 | 10:42 PM
ModularTurbo's Avatar
Actually I believe you are on the wrong side of the scale.
I use timing retard on my 2 step.
Try -1 or -2 or Zero timing and add extra fuel not much since E85 lowers EGT's so much you won't need it pig rich to keep from over heating the turbine wheel.
FYI on my drag car I use -1 and 10.6:1 (gas wideband E85 reading)
Makes 30psi bouncing off the 2 step with the clutch pushed in!!!!
Old Jun 18, 2011 | 10:53 PM
Boosted3rdGen's Avatar
+1 retard timing to build boost with 2 step.
Old Jun 19, 2011 | 06:48 AM
Nitroused383's Avatar
Not in all cases with a manual you want to retard timing. With an auto you add timing to build torque to get up on the converter.
Old Jun 19, 2011 | 07:21 AM
gennex's Avatar
yes i have th400 with a tbrake.
Old Jun 19, 2011 | 02:48 PM
I stand corrected, I did not realize this was an auto car.
Old Jun 20, 2011 | 08:39 PM
LSXFORMULA99's Avatar
so with a auto you want to add timing to build boost? im trying to figure out with one i want.
Old Jun 20, 2011 | 08:47 PM
Ya agreed auto car needs to be treated like its going down the track as far as AFR and timing are concerned on the converter
Old Jun 22, 2011 | 02:43 AM
i will have to have more timing in the car on the two step than i run at wot?
