Our Turbo 5.3 and new stock bottom end record attempt (video)
Old 06-22-2011, 01:44 AM
  #61
71 chevy's Avatar
Originally Posted by skinnies
Yes, I prefer it, but the converter was just made too tight. Even now that the same converter is in my ltd and making a lot more power it is still too tight with tractor fluid.
great info. thanks
Old 06-22-2011, 02:05 AM
  #62
b00sted's Avatar
Originally Posted by Mattsv8
So if my hp goal is 750 whp and more street manners than the ls6 cam would work well
We ran an LS6 cam with 1.8 rockers and comp springs in an otherwise stock LS1 motor. It was a nitrous setup, but it worked awesome. The rockers offer a nice little boost in lift while retaining a factory idle and general 'feel'. I'm a big fan of that cam.
Old 06-22-2011, 11:19 PM
  #63
slocaddy's Avatar
i shouldnt have read this. very cool truck- sleepers are the best
Old 06-22-2011, 11:21 PM
  #64
overhere's Avatar
Originally Posted by turbodiesel
Forgot to add the Air inlet temps are -10 degrees when spraying infront of the compressor wheel at 15lbs of boost. If spraying after, into the charge-pipe, they are 70 degrees. Thusly no intercooler is needed.
what is the mixture your spraying?
Old 06-22-2011, 11:37 PM
  #65
kmracer's Avatar
100% nitrous. its a dry 125 shot.
Old 06-22-2011, 11:57 PM
  #66
02sleeperz28's Avatar
Sick S10 and cool build.
Old 06-23-2011, 12:38 AM
  #67
Busy Mopper's Avatar
r u spraying out of the hole only or the whole way down?
Old 06-23-2011, 08:50 AM
  #68
fastimes's Avatar
thanks guys for all the props. turbodiesel and i have put alot of r&d work in this thing on the streets to get it at a safe power level to make it live. to answer some questions and pm's, we are spraying this thing on the transbrake on the line to get it to spool. we spray the whole way. data logging, it makes just shy of 25lbs with the nitrous. 20 w/out. the springs have been changed on the first video to prc .675. we ran the ls6 springs until about 2 weeks ago. the first video was the first runs on the new springs. we are only spinning this thing 64 to 6600. 3.08 rear gears. i drive this thing alot and dont like spinning the guts out of one on the highway to keep up with traffic. it is a 125 dry shot. we started around 50 and just worked up to it. the second video was with a 50 shot, 1.38 60', and after letting out and getting back in it, it ran a 6.45 @ 114. that was the ebay 67mm turbo. the boost was around 20. just some junk log headers out of mild steel that we built that we repair on a weekly basis. i will get some pics up soon. when we put the 6.0 in a few weeks, i want to build some stainless headers to cure the repair problem. lol.
Old 06-23-2011, 09:43 AM
  #69
91blowthru's Avatar
Are the headers schedule 40? Or regular exhaust pipe? Would love to see pics! And what size downpipe??
Old 06-23-2011, 02:09 PM
  #70
MrPotatoeHead's Avatar
Can you send me a couple underhood pictures, is like to do the exact set up in my car.
Old 06-23-2011, 02:19 PM
  #71
why r u repairing the log manifold ? is it warping?
Old 06-23-2011, 04:17 PM
  #72
fastimes's Avatar
i don't know what sch it is. just some tubing we had laying around. just the turbo side is the problem. for awhile the turbo weight was suspended on the header. so we cured that, and now it just finds a weak spot and blows a hole. controlled boost leak as we call it.lol the heat cycles are whats bad on the material. thats why now we want to go with stainless. just lessons you learn as you go i guess. when we first put this together we never thought it would be capable to do what it is. pass side header is 2.25 with 1.5 primaries and driver is 2.5 with 1.5's.
Old 06-23-2011, 05:04 PM
  #73
2002_Z28_Six_Speed's Avatar
Too awesome. You just won +9000 internet points.
Old 06-24-2011, 09:09 AM
  #74
2fast02TA's Avatar
Sweet build guys! My brother just got his stock bottom end 5.3L with an 85mm turbo together this past month. Still has some little things to buy before taking it to the track but he is hoping to make some 5 second 1/8th mile passes in it as well.
The car is a 95 camaro that ways 2900 with no driver.
Old 06-24-2011, 11:32 AM
  #75
7 Second Club
Phil99vette's Avatar
Pretty kick *** results. The race weight and 1/8 mile play a role in it lasting.
Old 06-24-2011, 12:59 PM
  #76
turbofreek's Avatar
I Just got a coupe amd looking to run a 5.3 turbo setup. Was expecting some 9's, but seeing somebody run 8's is killer. Wonder if I could get a large frame 76ish mm to beat on a 8 sec pass? Definitely going to investigate further.
Old 06-25-2011, 07:37 AM
  #77
LS1LT1CAM's Avatar
your setup is badass, makes me a little scared about spool time for my car
I have a stock short block 5.3 with a 85mm 1.0ar t6 flange
Should have it on the dyno next week
Good luck on the record
I am after that same record
Old 06-25-2011, 07:40 AM
  #78
skinnies's Avatar
I like to hear this, motivation for me to work on my car.
Old 06-25-2011, 08:06 AM
  #79
71 chevy's Avatar
if you need any more motivation, Im gonna try and beat the record next week. with a 4.8
will it happen? probably not, but Im sure gonna give a valiant effort hehe
Old 06-25-2011, 10:52 AM
  #80
6point7s14's Avatar
lol fellow 4.8 guy here... gt47-80 and custom eps cam in a irs 95 240sx lol... im going for it too
Quick Reply: Our Turbo 5.3 and new stock bottom end record attempt (video)
