LSX alternator relocation kit
Old Jun 20, 2011 | 08:28 AM
ModularTurbo's Avatar
Of course it has been tested, it is very strong and rigid with perfect alignment.
More pics added to the first page.
Old Jun 20, 2011 | 09:31 AM
Chris@CBR's Avatar
I have a standard truck ALT that I'm going to test fit later this week just to see how it fits.
As far as the bigger high AMP truck alt goes I don't have one to test.
If you will mail me yours and pay for the ride both ways I will test fit it to see if it clears and if the belts we stock will work. If it fits and clears it may need a different belt. If you want one I'll supply the correct belt for the same price.
Old Jun 20, 2011 | 11:24 AM
Chris@CBR's Avatar
Ok it's later this week, LOL!!!
I just got threw test fitting a standard truck ALT, it fits as good as the F-Body ALT.
It actually has more fuel rail clearance than the F-Body ALT.
Rob will have pic's up shortly.
Old Jun 20, 2011 | 11:35 AM
Truck alternator fitment:
Old Jun 20, 2011 | 12:03 PM
89ROC-Z's Avatar
How much without the Belt? I'm not running power steering so need a different length belt anyways.
Old Jun 20, 2011 | 12:22 PM
You cannot buy it without the belt it is a package deal.
Old Jun 20, 2011 | 12:45 PM
MUSTANGBRKR02's Avatar
Those pics look a ton better. I'll be ordering one very soon. Good job guys!
Old Jun 20, 2011 | 01:22 PM
chevymec's Avatar
Would you even consider it? Im not running p/s either.
Old Jun 20, 2011 | 01:46 PM
1INSANEGTO's Avatar
Nice can you guys make one of these??? This is a power steering relocation kit.
Old Jun 20, 2011 | 01:50 PM
1INSANEGTO's Avatar
Also anyway that can be made with a lower profile? Such as this?
Old Jun 20, 2011 | 02:00 PM
Right now we have a belt for every kit.
I had to do lot of sweet talking and spend a small fortune to get the belts at a deal
to where I could make a few $ on the belt and not tear you back pocket off doing it.
The target customer is someone that needs to move there ALT and keep everything else.
On the next batch of brackets I will make a few extra with the right length belt for PS delete.
As far as I know no one makes a kit that is turn key.
You are left to go and buy something extra, belt, ALT, pigtail plug, or something.
Old Jun 20, 2011 | 02:04 PM
  #32
Chris is working on PS kit.
Why would you mount it there and move the ALT?
Old Jun 20, 2011 | 02:22 PM
  #33
ls1curt's Avatar
looks good, like the tensioner setup alot better then other relocation brackets. pm me your paypal address.
Old Jun 20, 2011 | 02:40 PM
  #34
call to order
Old Jun 20, 2011 | 03:20 PM
  #35
ls1curt's Avatar
just ordered it, thanks man
Old Jun 20, 2011 | 03:25 PM
  #36
thanks for the business Sir
Old Jun 20, 2011 | 03:30 PM
  #37
Nitroused383's Avatar
Great looking setup you guys have going on there. You sure that will clear a stock ss hood?
Old Jun 20, 2011 | 03:31 PM
  #38
thanks for the compliment.
Also it sits lower than the one you made.
It barely puts the Alt 2 inched above the oil filler cap.
Old Jun 20, 2011 | 03:56 PM
  #39
Mine sits a little lower than this one but not much. I pivot the alternator off the right bolt hole on the cylinder head. You guys might not realize this but there is a lot of thought put into a relocation setup like this. I like the adjustable tie rod on this, I thought about designing mine so it used one.
It's about time people started marketing these,it's a pain to have to make your own. All a guy wants to do is bolt a turbo setup on, not have to engineer the whole thing. Good job guys, it's a great kit.
Old Jun 20, 2011 | 04:02 PM
  #40
Thanks for your blessing.
You are right it took Chris an entire day to nail this down. It takes a good deal of thought to get everything lined up just right, while also accounting for belt tension and spacing for aftermarket fuel rails/valve covers etc.
I would also like to point out that I have seen ALT relocations where the rectifier bridge cooling duct was removed. This shortens alternator life and should not be done.
Nitrous383, Chris and I appreciate the kind words thank you.
