what should I change about my turbo system
Ok I have a great car and it runs great to, put down about 600 rwhp, I want Opinions on what needs changed, I'm looking for high 9's in the 1/4. Its a 88 stang with the ls6, 4l60e-tci 3500 stall, 8.8 rear with 3.73's, has mp70 turbo, 48mm bov, 50mm w/g, ls6 is stock besides arp hardware. What would need changed to be a good 9 second car, has full suspension, cage and sticky tires already
Haven't made it to the track yet, not sure if it will hook good enough to get 9's like I want, it spins the 275-60-15 mt et's on the highway at 70mph
Has good tires, they might hook at the track if I get them nice and hot, suspension is all aftermarket besides I need to find a rear sway bar and some coil overs maybe
Ya you reaaally need to get a baseline. Go to the track with it just like it is and make some shakedown runs. That will tell you what you need to start fixing. Its not about the tires , or turbo piping, or suspension. Its about the whole combination and how it all works as a whole.
You need to get some passes under its belt. period.
As soon as I get a rear sway bar on ill go get me some times and see how it does, not really wanting to take it with out the sway bar on the rear bc its twisting hard
Ya I heard the 70mm is close to maxed out on my car or something, I'm going to turn it up to 12ps1 and take it to the track, will a 76mm tubro be a lot better then what I currently have?
